Asus Nexus 7 2013 Won't Connect to Go App
Discussion in 'Pro/Adv Discussion' started by eBoon, May 23, 2016.
  1. eBoon
    My new P3P working just fine with my iPhone but no luck getting it to connect to my Nexus 7 2013. Tablet seems to work with Litchi though.
    Any ideas? Anyone else with this issue?
    Tablet is up to date with latest firmware revision.
    Thanks,
    Tom
  2. dirtbird
    That is weird. I just purchased a used one and just completely wiped the device when I got it. I updated the OS to the latest version, which I think is called Marshmallow. Once there the first thing I did was install the DJI GO app. I thought I might have to go in to developer mode and enable the USB as well as some other tips I've seen online, but I didn't need to. It just connected right away.
  3. Fat City
    near Boston, MA
    The problem might be with the USB connection. If you connect the Nexus to a computer using the same USB cable, can you read and write files?
  4. eBoon
    Tried a couple different cables, but I'll double check.
  5. Fat City
    near Boston, MA
    The other possible USB problem would be with the tablet's USB jack. If it's been used a lot for charging, it could have been damaged.
  6. eBoon
    ....and never mind. It's working now - no idea what I did to fix it:(
    Thanks for your help all!
    Tom
Similar Threads - Asus Nexus 2013 Forum Date
Asus Nexus 7 2013 Pro/Adv Discussion Sep 8, 2015
Bright Screen ASUS Nexus Tablet General Discussion Apr 18, 2016
Asus tablet work with Litchi Control (Go, Litchi, etc..) Dec 31, 2017
New Asus zenpad 8" tab- General Discussion Dec 1, 2017
Anyone heard of Pegasus Aeronautics? General Discussion Aug 19, 2017
