Are my cells too unbalanced (new battery)?
CJD
Hi all,
I have only flown my P3A once so far and now charged it back to 50% as might not be using it for a few days.
There is quite a voltage difference between cell 1 and 4 and i was wondering if this is a problem? I read online that new batteries can take a few cycles to balance themselves so was wondering whether I should be worried or not?
Picture attached showing the current cell levels. This is at 51% charge.
Edit:
And here is the healtyhdrones output:
Hi all,
Edit:
@CJD I can't believe you never had a single reply to your post from 8 months ago but if you are still around and looking for an answer I can suggest one. You may have found it already when you fully charged the battery and that is the voltage is only balanced out on a full charge. Then if it varies again on discharge on the same cell you have a problem that needs to be watched, if it happens repeatedly then you have a dud battery, send it back to DJI. Of course if you have a battery cell voltage varying from the other 3 while flying DJI Go will most certainly be telling you all about it and even reducing the battery power output if its a serious variation to reduce the probability of a complete battery failure and the Phantom falling out of the sky.
What took you so long!? [emoji23]
jorge sanchez
