App like Litchi?
Poland
Hi everybody,
I'm new to this forum. I noticed that there is a very interesting app called Litchi. Is it working only on Vision version or standard Phantom version too? I can't find this info... Could anybody recommend some similar program? I've got Phantom 2 v2.
Thank you very much for any help.
The P2 v2 does not use wifi as both use the same 2.4Ghz frequency and would interfere with one another. P2 vision, vision+ and vision+ v3 use wifi for video communication because there TX frequency is 5.8Ghz. Hope this answers your question..
Reactions: Khan
Thank you very much, that helped. So there's no possibility to use options like "follow me" or "POI"? Any hardware upgrade?
None!
Reactions: Khan
Since you have a P2 v2 non vision you start looking FPV (first person view) equipment such as 5.8Ghz transmitter (real time video), mini iOSD ( for telemetry), plug n play cable and 5.8Ghz monitor/receiver. Will cost between $250-$350 dollars. All the equipment I use is listed in red at the bottom of this post.
Reactions: Khan
wouldn't they have the ability to build it into Ground Station? I can't imagine why they couldn't upload that mission information to the datalink.
You're right, I know. I'm about to buy similar stuff next week. BTW: during installing gimball (I haven't done it yet, I've just received my gopro) and transmitter is it necessary to hide any electronic parts inside drone? Other words - do I have to open the drone? I found two different tutorials about that...
You can go with a ground station if you have the as they are not cheap systems. There are lightbridge decisions under the P2 tab check it out
Reactions: Khan
You're right, I know. I'm about to buy similar stuff next week. BTW: during installing gimball (I haven't done it yest, I've just received my gopro) and transmitter is it necessary to hide any electronic parts inside drone? Other words - do I have to open the drone? I found two different tutorials about that...
I put both the mini iOSD and the anti-interference board inside the shell with only the TX and gimbal outside as it makes for a clean look and less drag. Here's a photo of the mini iOSD and a video for the interference board install.
Reactions: Khan
Thank you once again, you're very helpful. I think I'll do installation like you did. Lightbridge is too expensive for me :-/
The DJI Ground Station for the iPad or PC is about $200. Lightbridge on the other hand it about $1200. I use the former.
tpren3
