I've seen a few threads where a similar thing has been asked - but thought I'd try again and see if there are more suggestions or any new apps.
I need an app where I can select an area on the map and it will automatically create survey lines (and you can set height, overlap, speed etc) just as if you were capturing images for photogrammetry. But instead of still photos I want to record video. The purpose for this flight is so I can select a river on the map and then get a video capturing the entire river so I can count animals in the water. And then I want to do this at different heights (trying to figure out which height is best to see animals). I know I could use something like Litchi but I would have to set the waypoints manually and I don't want to do that - I want to select the area and then have the app create survey lines so I know for sure that every section of the river will be covered (and the same area will be covered even when I fly at different heights!).
So far the only app I have found to do this is Drone Harmony but I'm having a lot of trouble getting that to work (there is an issue where it wont connect to the drone). Anyone know of another app I can use for this?
