You won't get the map overlay w/o an iSomething, but you'll get the boost, which IMO is worth the $10 alone because it definitely works.
bbfpv said:You won't get the map overlay w/o an iSomething, but you'll get the boost, which IMO is worth the $10 alone because it definitely works.
bbfpv said:I can do 90% of any mods myself. I pay for convenience. You can build an fpv quad yourself too, or you can buy one rtf... thus this forum and my recommendation.
Just had a brief look on phantommods.info. I see some pitfalls and concerns to me (current owner or the next owner) if I follow those instructions, such as:BioTeq said:bbfpv said:I can do 90% of any mods myself. I pay for convenience. You can build an fpv quad yourself too, or you can buy one rtf... thus this forum and my recommendation.
I didn't say you couldn't, I just said 10$ for something that can be achieved in 20 minutes is not worth it. The only reason to pay for fpv booster is if you buy it with all the other modules, booster alone is not worth it. In fact I think it should be freemium for the more advanced options, of course there are no other modules on android so all of it becomes theoretical.
There will be a "Combine Home/Pilot" option in the next release. For those non-GPS devices (such as Wifi only iPad), you may combine home point and pilot point on the map. This option will be first available in the upcoming Android version FPV Camera.Vas Deferens said:After using this app a bit more, I'm finding that this app works a lot better with a GPS equipped device such as a iphone or a 4G or LTE iPad.
With the wifi iPad, it locates the Phantom and the home point perfectly.
But the location of the transmitter with it's attached iOS device, or the "pilot position" might be significantly different and a distance away from where it actually is or shows up on the cached map.
I have two iPad minis, one wifi only, one with GPS. I also carry an iPhone 6 plus. With our GPS iPad and even my iPhone 6, running the FPV Camera app, all three, the home point, the Phantom and the iOS device location are precise. You don't have to fool with caching the Google maps and then loading up the Google map image where you plan to fly before leaving home. A GPS enabled iOS device will of course show you very accurately where it is on the map and in real time.
The above is important also if you get to your pre planned flight area and discover that you have to go to another area. If you've cached the map for the first area, then that may not work for you if you have to move to another area.
With the GPS equipped device, my home point, transmitter location/pilot point, and Phantom can be seen exactly where they are on the map, prior to taking off.
Bottom line, after using this app more, I prefer to use it with a GPS equipped iOS device, as opposed to a wifi only iPad, and would use it with an iPhone which has GPS, before I would use it with a wifi only iPad, even in light of the difference in screen size between the two. And that screen size difference is of even less significance for those using an iPhone 6 plus.
I like this app over the DJI app, which is not bad itself, and I give this FPV app an enthusiastic thumbs up. While it of course works with a wifi only iPad, I think that maximum benefit from it is more easily and consistently had with either a GPS equipped or 4G LTE iPad or your current iPhone.
PVFlyer said:There will be a "Combine Home/Pilot" option in the next release. For those non-GPS devices (such as Wifi only iPad), you may combine home point and pilot point on the map. This option will be first available in the upcoming Android version FPV Camera.Vas Deferens said:After using this app a bit more, I'm finding that this app works a lot better with a GPS equipped device such as a iphone or a 4G or LTE iPad.
We have been gathering a lot of feedback in the past 2 months on both FPV Camera and Flight Tracker. We have to prioritize the lengthy enhancement list, though some items are out of our scope for the time being.Vas Deferens said:Great news!!!
Any time frame estimate as to when the next release of this app will occur?
In About > FPV Camera > FAQ section indicatesJDNC said:And...are you going to include waypoint flying in the near furture?
PVFlyer said:In About > FPV Camera > FAQ section indicatesJDNC said:And...are you going to include waypoint flying in the near furture?
Q8. Why Ground Station (Waypoint) feature is unavailable in FPV Camera?
FPV Camera brings a complete new FPV experience for flying DJI Phantom 2 Vision+ with innovative features. However, we do NOT intend to replace or duplicate DJI VISION app. We don't see the value of duplicating DJI Ground Station feature for the time being, unless we find some creative ideas of implementing Ground Station. We prefer innovation instead of copycat.
Uptowndisco2 said:PVFlyer said:In About > FPV Camera > FAQ section indicatesJDNC said:And...are you going to include waypoint flying in the near furture?
It would be great if you would reconsider the groundstation , it would save swapping back and forward
between different apps to achieve how you want to fly and achieve on the flight , I dont see it as copying
anyone , just makes a fuller featured app.![]()
Wi-Fi Wand is based on pilot point of your mobile device. It uses device's GPS/compass to identify your location and orientation on the map, assuming the device and range extender mounted on RC transmitter.Vas Deferens said:Used my tripod today to mount my iPad. Noticed that the wifi wand feature was responsive to the actual orientation of the iPad as opposed to orientation of the RE 700.
I didn't realize this earlier. The "wand" seems to indicate how well, or not, the iOS device is actually lined up with the aircraft.
In other words, the "wand" image only turns or moves toward the direction of the arrow indicating the aircraft on the map as the iPad turns towards it, and not as the RE 700 and the transmitter turns toward the direction of the aircraft.
This is great if your iOS device is mounted atop your transmitter. Then the iOS device, the RE 700 and the transmitter all move as a unit. But with iOS device is separate from your transmitter, such as on a tripod, the wand seemed to only move if the entire tripod were moved.
Move left or right of the straight line"wand" image, and you can't put the wand image onto the aircraft image by moving the remote/RE 700. If you want the wand image onto the aircraft image, you need to rotate the tripod/ios device toward the phantom.
It seems that the app was designed for a transmitter mounted monitor
PVFlyer said:Wi-Fi Wand is based on pilot point of your mobile device. It uses device's GPS/compass to identify your location and orientation on the map, assuming the device and range extender mounted on RC transmitter.Vas Deferens said:Used my tripod today to mount my iPad. Noticed that the wifi wand feature was responsive to the actual orientation of the iPad as opposed to orientation of the RE 700.
If you mount both mobile device and RE700 (directional antennas) with the same orientation on tripod, it should also work.
msinger said:You could also get GPS on your iPad by buying this:
http://www.amazon.com/gp/product/B006M4 ... ZME2D5MPSF
And, installing this app:
https://itunes.apple.com/us/app/bluetoo ... 61436?mt=8
ccase39 said:I just turned it on and everything looked cool but I got an invalid battery warning. It just popped up on the screen and quickly went away. It was a fully charged battery that came with the Phantom I got in today so I doubt its a bad battery. Everything looked good with it in Assistant anyway.
