Anyone seen or used this???....
United States,Houston, Tx
I was perusing on ebay for some carbon fiber legs for my P2V+, and came across this deal...... I have only seen the level that you install on the back of the TX. Has anyone seen this type, or used something similar? Sure is priced right....
Moose
All they are selling is the rotary potentiometer as far as I can see, and that wont work unless you go back to a previous firmware version and NEVER update. Its also a little more fiddly to resolder to the TX but dont be fooled into thnking they are offering you some kind of wonder 7th channel hack - read the extensive threads on this !!
The only person currently offering a tilt lever solution are Drone Expert which works with the current firmware.
I don't think you can load a earlier firmware that works with the gimbal. The older firmware was for the pv2 , the + has a brushless gimbal.
This still works with the P2 non vision. It's just a pot to replace another pot in a different location...
I don't understand... it's just replacing a pot by a pot! WTH a firmware version has something to do with this?
You can't use the 7th channel with the current firmware. Courtesy of DJI :-(
Yes I use a custom pot on the frontside with firmware 2.00.
Read the threads and you will see why.....nasty old uncle DJI says you cant !!
viewtopic.php?f=27&t=13232
Not on the P2 Non vision, I should have mentioned it. There is no difference if it is version 2 or 74. If the lever is still alive, and it should for the zenmuse, the pot stays a pot, and can be deported of course.
I realise that the Op is talking about a V+. my bad then!
(but I remain right about the P2 NV ...lol)
