Any tips from anyone?
Finland(Turku)
I have one P3 4k drone and i have two seperate controllers, same model GL358wB.
My broblem is that only one of them works with C2 pressed down + Right roll(Gimbal horizon tilt) quickkeys works, second one doesen't work, how this is possible? Both controllers C2 button works flawlessy in normal use but other doesen't work with C2 + Right roll combination.
All hardware is same in both cases, only different controller. DJI GO says latest firmware in both controllers.
Weird.
Jani
I suspect a different FW on controller is troubling you. Many details are not published by DJI.
In with P3 4k it gives an alert if there is no latest Firmware, how i can see what FW is in P3 4k Controller? When i connect controller 1 it DJI Go says latest Firmware, when i connect controller 2, same happens.
Make sure the new controller is linked to the craft. I assume you have done that, right?
Of course and flyed it with it too. C2 + Roll Quickkeys doesen't work with this controller, all is fine in other cases. With other controller C2 + Roll works like charm.
How i can return default FW with P3 4k, if i try to update FW all again.
