- Joined
- Oct 7, 2016
- Messages
- 8
- Reaction score
- 4
- Age
- 60
Following up on Brockrock's great video from Mystic Seaport, here is one from me of a sunset flight over Lake Norman in Mooresville, NC. The flight is 7.5 minutes long. And for just over 5 minutes of it, my RC is completely out of communication with my P4. There are a lot of tall, dense trees between my house and the lake. So this is a truly autonomous flight.
The process is as much fun as the result for this type of mission. I probably flew it more than 20 times before I got to the result I wanted. Because you can't view what the P4 is seeing until after it gets back, I had to start at a solid high altitude to perfect the path. Then I was able to edit in elevation changes. So I'm at 200 feet to clear all of the trees but I get as low as 30 feet at some points over the lake. Finally, I had to tweak the POI's so I could get the right mix of sunset and shoreline.
No, I didn't just wing it and suddenly do a mission where I'm out of communication for 5+ minutes. Trust me... it took a while to build up to it. But once you build the confidence, I am a die-hard Litchi fan.
Video below and also a link to the Litchi mission on Mission Hub: Mission Hub - Litchi
