Alternatives for lifting camcorder
Semaphore, South Australia
Hi
Does anyone know of any cheap alternatives to the (dji s800 I think) that could lift the panasonic hc v750 or does anyone have any leads on how to build one capable of doing so. Hoping to keep it below $2,000
Thanks in advance
You can start with a frame like this...
http://www.copterstar.com/index.php?rou ... ct_id=2442
or this
http://www.hobbyking.com/hobbyking/stor ... 00B01.html
add a flight controller
http://www.hobbyking.com/hobbyking/stor ... Combo.html
or
http://www.hobbyking.com/hobbyking/stor ... T_60_.html
(i'd go with the Mega master set, all ready for waypoint programming)
some good motors...
http://www.hobbyking.com/hobbyking/stor ... unner.html
or t motors, you can research sizes and stuff.
Some decent props, 4s/6s 8000mah batteries (4 or more) ,turnigy esc's, 45amps, power distribution board, and any other odds and ends you need, gimbal controller, etc etc.
Mcyz250 said:
Hi
Thanks in advance
You would have to build it but it is possible.
http://www.foxtechfpv.com/tarot-t810-he ... -1119.html
You could get a minimal capability within 2K probably. I built mine with higher end stuff and it came in about double that not counting camera. Additional costs will be batteries, charger, tx/rx, gimbal, fpv - which can add up quickly.
See my (semi) build thread here: http://phantompilots.com/viewtopic.php?f=21&t=10744
