- Joined
- Dec 15, 2018
- Messages
- 6
- Reaction score
- 1
- Age
- 25
Sadly, a mistake made too often is when people take off prop guards and their longer screws and then reinsert the longer screws which then ruin the motor windings. The result is ESC errors. I’m not saying this is your issue, just likely what @Starz was talking about. Another common issue is cutting the motor wires and not removing the enameling (coating) on the wires before soldering them and putting it all back together. We seem to see that one a few times per month, though we’ve seen it a couple times just this past week.What do you mean?
I see an error here.......soldering is the way to go....do not splice. Unless you are using solder splices.I never put the screws back in the motors but I had to cut the wires for the motors to put the motors in the new shell.
What is the magnet wire?Did you solder the motor fly leads directly to the ESC boards? The sometimes considered quick dodgy method of cutting and splicing wires almost always leads to a poor outcome, you need to remove the insulation from the magnet wire to have any hope of getting a satisfactory connection.
Also double check your connections between the 3 in 1, ESC and MC boards.
If you have butchered the motor wires you will be able to fix them providing you carefully strip the insulation and solder (cover with heat shrink).
He is probably referring to 32 gauge wire.....You have to remember that when you ask for help, you may get answers that are in native lingo. Happens all the time........there is no real "magnet wire".....in this terminology.What is the magnet wire?
It absolutely literally is magnet wire I was referring to- it is real.... The fly leads from the motors are simply extensions of the wire used to wind the stator coils (electromagnets). Each of the three coloured sheaths contains two strands being extension from series wound field coils (three pairs wires which when terminated present a delta connection to the ESC inverter outputs).He is probably referring to 32 gauge wire.....You have to remember that when you ask for help, you may get answers that are in native lingo. Happens all the time........there is no real "magnet wire".....in this terminology.
Flux. Copper needs to be clean. Local hardware store sells it in a liquid form. Use a qtip to apply to the wire. Somewhat caustic and may stain some materials. Probably some YouTube vids that may help. Practice on something other than your phantom.
Haha how do you people know these things!?It absolutely literally is magnet wire I was referring to- it is real.... The fly leads from the motors are simply extensions of the wire used to wind the stator coils (electromagnets). Each of the three coloured sheaths contains two strands being extension from series wound field coils (three pairs wires which when terminated present a delta connection to the ESC inverter outputs).
