Air Blade Antennas
  • Thread starter Thread starter Deleted member 18643
  • Start date Start date
I've used the air blade, cloverleaf, and mad mushroom as transmitter antennas and I honestly haven't been able to tell the difference. The biggest difference I noticed was changing to a helical on the receiver end.
Currently, I'm using the air blade with an Immerision 600mw transmitter and a 5 turn helical on Fatshark Dominator HD goggles with very good results.
If you don't want to do the helical, the mad mushroom on the receiver end works well with the air blade on the vtx.
Thanx.I am in process of upgrade.Hero 4 and FPV.I chose all DJI compatible iosd,AVL58 Lite,andDJI Hub and cables with Air Blade antennas.Have not fired up system and performed test run.Waiting for camera.Hopefully be off of the ground within a week.Also plan on using immersion patch antenna.Will post review after test flight.Thanx again.
