A little overwhelmed :(
Oklahoma City
Said it before, and I'll say it again - I'm a noob :)
I've been reading through all the various posts about extending the range on the P2V ... but the more I read, the more confused I get.
It seems my LHCP brain is fighting with my RHCP brain and it's causing my dbi extender to do pinwheels in an omnidirectional fashion :(
Not wanting to hijack anybody's thread with noob questions, I'm wondering if there is an online primer somewhere that can give me the basic information I need to follow these threads?
Thanks in advance!
Thanks in advance!
Sometimes I know how you feel .... just start out slow and read read read ..... some threads are replicated so can be confusing.
The Antenna range situation, apart from some guys experimetation in extreme ranges, seem to now have been covered by the intro of new products specifically for P2 and P2V's by these guys - http://horizonfpvantennas.mybigcommerce.com/
Gimbal mods seem to be looking mainly towards latest from - rotorpixel - http://www.rotorpixel.com/
Well what's your question?
I'm am buying my stuff here
http://www.fpvlr.com/store/
LHCP and RHCP just mean left hand and right hand they don't mix
If you don't want to touch the pv2 then get a LHCP antenna on the repeater
If you plan on adding antennas to the pv2 then it doesn't matter if you get left or right they just have to match
I got a LHCP helical cause I didn't plan on modding the pv2
Thanks GMANNZ, I appreciate the links.
As far as the gimbal is concerned, I think there will be more options coming soon, so I'm going to wait just a bit longer before I make that purchase.
Looking at Horizon FPV's website pretty much just adds to my confusion. Not knowing what any of those acronyms and abbreviations mean, nor how they relate to the P2V just adds to my befuddlement :(
I guess I'm looking for a basic understanding of the technology - without that I have no clue about what I need, nor do I understand what's being discussed and sold.
;) .. yep I was in same boat ... just took lots of reading and research ...
Yes, there's so much to learn with this hobby! Here's a good primer on the technical magic that makes all this good stuff happen. https://vimeo.com/8826952. Someone on this forum posted this link a little while ago, but I can't find that original thread. Sorry!
I cant take that video , makes me want to beat my head against the wall. Way more jabber than is needed to explain. :roll:
Im sure its helpful and explains something. :D
Thanks for sharing - answered several questions, but gave me a few (dozen) more :)
In the vid, he says that the "circular" probably should be called "corkscrew". Does that mean it's the same as what people here refer to as "helical"? And the RHCP/LHCP is merely referring to the direction of the "screw"? Can somebody briefly explain why the 2 can't be mixed? Is it something as simple as a signal incompatibility (if there is such a thing), or is it something more sinister?
Since I'm not looking to beat any distance records but merely extend my range a bit (the other side of my property - no more than 2500 ft from my "base" in any one direction), my gut is telling me that I'd probably want something like the "circular" that he refers to. It sounds like as long as my TX is pointed in the general direction of my Vision, I'd be fine.
That there was funny, thanks for the laugh.
I can completely understand where you are coming from. I know that most do not like to dive into the 17page long threads, but it must be done. There is a wealth of knowledge that can be obtained by taking the time and sifting through the information. The only way to true knowledge is research, research, research.
Most threads lead back to just a couple that are, unfortunately, a tad bit on the EXTREMLY long side. I would suggest to find a time when you have awhile to sit and read and start digging. You will find that you get more involved and want more information as you learn what all this means.
Good luck!
The more turns and higher gain the more directional your system becomes
The 6.5 turn helical from fpvlr is good for 3000 ft by itself
The parasitic disc has also been tested to 3000 ft and is smaller
No need to mod the pv2 to get the range your wanting
Here is what the 6.5 turn looks like mounted
Here is where I got it
You want LHCP if you don't want to change anything on the pv2
You're right, of course. And I have read through the threads here. But I guess my problem was that I didn't know what the terms meant, so I was having a hard time deriving the meaning of what I was reading.
However, having watched the above video, parts of what I've previously read are starting to make sense.
I started a new thread because I didn't want to hijack an existing thread with low-level kindergarten questions :)
And yes - rest assured that I'll be re-reading those other threads. But only after my head stops spinning ... too much diversity polarization last night, I think :eek:
Thanks for the info and the pic. Based on what I saw in the video, and what I've been able to deduce elsewhere it seems like that will be the direction I'm heading. However, I might have a look at the parasitic (simply because I like the name LOL).
intertronixlabel
