FangsCPO said:What do you mean by anemic and cold joints...... See how much of a rookie I am?
I just wonder if 45? watts will be high enough? 100 seems like a lot. I think I'd be more comfortable with something smaller. Probably do less damage tooFangsCPO said:I guess it is a matter of choice and what you are comfortable with. This works perfectly for me and I'm no expert at soldering.
Thanks-but I don't think either of those will work-the diameter of my tubes appear to be 12mm.OI Photography said:havasu, I don't know what diameter your arms are, but if they happen to be 16mm you could still use Tarot motor/ESC mounts like these, just for the ESCS's, and mount them close to the body: http://www.tarot-rc.com/index.php?main_ ... cts_id=212
If those won't fit your arms, there might be similar solutions in whatever diameter you have. Here's something similar for 20mm: http://www.ebay.com/itm/DIY-Motor-Mount ... 1266065792
Yea...but, I don't want to run the mains that far out. It's kind of a conundrum. DJI gives you maybe 3 inches of main power wires, and the control lead to Naza is maybe 6 inches. And there in lies the problem, the control wires that plug into Naza-that's the length I have to work with.ElGuano said:Those ESC mounts are a good idea but if you put them close to the frame, you have to get fairly creative with your wiring. Either drill a hole in the cf tubes or double the wires back into the frame to get them out to the motors. IMO that's probably the cleanest way to do it.
I think you may have misunderstood--what I'm saying would put your ESCs as close to the center frame as physically possible while still being boom-mounted, with hidden wiring inside the tubes.havasuphoto said:Yea...but, I don't want to run the mains that far out. It's kind of a conundrum. DJI gives you maybe 3 inches of main power wires, and the control lead to Naza is maybe 6 inches. And there in lies the problem, the control wires that plug into Naza-that's the length I have to work with.
Yea-that's what I was going to do with the ESC's. As for "crimping" the leads-not sure what you mean? I can shorten wires and rejoin the ends with the mesh, wire wrap, solder, heat-shrink method. But-I think what I'm going to do is use some small zip ties to bundle things together, or, use heat shrink to wrap wires up in bundles so there are less individual wires running around.ElGuano said:I think you may have misunderstood--what I'm saying would put your ESCs as close to the center frame as physically possible while still being boom-mounted, with hidden wiring inside the tubes.havasuphoto said:Yea...but, I don't want to run the mains that far out. It's kind of a conundrum. DJI gives you maybe 3 inches of main power wires, and the control lead to Naza is maybe 6 inches. And there in lies the problem, the control wires that plug into Naza-that's the length I have to work with.
Separately, I think it is well worth jumping into servo wire work. There is a LOT of tidying up you can do if you crimp your own servo leads,and you're no longer limited by factory-supplied lengths for pmu, GPS, led, canBus, ESCs, etc. Trust me, it makes building an entirely new, open-world experience.
Thanks.ElGuano said:Soldering is the first step, absolutely jump into it and get comfortable. Then you realize you are soldering and splicing all these fine servo (control) wires plugging into your Naza and rx, and it's an absolute mess of bulges, heat shrink and bad connections. That's when it makes sense to desolder the entire length of the spliced control wire, break out the 26-30awg wire and servo terminals, housings and crimper, and make your own custom length control wires. It's useful not just for wires that are too short, but also ones that are too long.
You can take off the top or bottom plate without removing the arms, but you have to be careful to support the remaining plate because it's not strong enough to hold the arms + motors without bending. The top plate has four points of contact so it's a bit stronger.
It is a lot harder to take the bottom plate off because your Naza and other components are is probably mounted to it, and soldered into it via power pads.
Welcome to the "club".Acill said:Hey everyone! Just got my F550 together with a Woo Kong-M system. Love it so far. I am still waiting for my extended skids to get here and I will put my FPV system in. GoPro Hero 3+ Black based with a Tarot Gimbal and a separate CCD for just forward FPV viewing attached to a video switcher with IOS mini and some other goodies. Pics to follow soon.
I'll get a picture of it later-but I was going to use the old plate as a template.ElGuano said:Be careful if you are drilling holes in the bottom plate to set screws. Unregulated battery voltage flows directly through the top and bottom of the bottom plate to the first set of curved holes, and you may create a huge short if you are passing screws through it without insulation.
Yea-I'm not liking this idea of drilling holes into the bottom plate. It would seem to me that a bracket must exist-or that I will have to make one, for the 2 fore and 2 aft rubber grommets to screw into, that will use the existing arm bolts to hold it in place.ElGuano said:The edges should be fine, but for the ones close to the solder pads look at the traces running under the pads to make sure you're not cutting into and potentially shorting them.
