100w charger voltage output
  • Thread starter Deleted member 27337
  • Start date
D
Guest
Has anyone measured the DC voltage output from the 100w DJI charger?
If so, what voltage did you see?
Thanks!
17.4V is what is spec-ed.
Do you suspect a problem?
Sounds good.
Not unusual for a bit of measurement error among different meters.
One should get ~17.5 volts
is 0.04v worth worrying about ????? I don't think so;) it still gets me to 100% charge
The voltage will drop probably with load (charging).
I have a Universal power supply which I can set the voltage and current.
The voltage does dip a little when max charge current is being drawn.
No of course not. Take 10 units and you'll get a deviation across them. Don't worry about it..
no I'm not worried I was just making a point:).
Robin what are you doing indoors, get out into that lovely weather, I think we've got 2 days of it next week:(
Been outdoors, been indoors, been cooking, planning next adventure.
Which reminds me I need to charge batteries :)
jorge sanchez
