- Joined
- Mar 23, 2017
- Messages
- 2
- Reaction score
- 0
- Age
- 62
Hi I have had the P4P for about a month and flown about 7 hrs, recently getting type rated in Australia and so now RePl and available commercial operations.
Below is a list of things I am struggling with and a few annoyances:
1. Moire and aliasing on Images.
I have tested many things to get great images, shooting PAL / 1080 / 50fps / iso 200 / F4.0 / Shutter 100 (Mechanical on and off) and using a ND 32 Filter. The ND does help heaps with exposure and totally needed for serious shooting. In post do slow the shots down in After effects 50-25fps and then de grain a little, but the aliasing in highlights is still there! I also used the "soft" camera function but didn't like that too much as whole image felt a bit too soft for me.
2. 4K files.
Big clunky files! my mac on a 30sec clip at 50 fps took about 30 mins to render ( 3 year old imac though) wont play real time in Premier (latest version) started only shooting 1080 as standard and if want to reframe then 2.7K at 50fps etc.
3. High wind warning.
Omg please is there a way to shut the front door on that warning??
4. Warnings and failures;
Micro SD card intermittent shot a heap on it to return home and it wont read in ANY of my 3 mac devices.
Red lines over the picture image and break up of image on ipad 3 (occasionally) also once when Phantom at was about 2K range base station disconnected, came back on second or so later.. phew....
Obstacle avoided at 40m above trees about 20m high, maybe a bird buzzed it I cant be sure but way way above the trees and had me scratching my head..
5. Gymbal after manovers not on horizon when rotating 90 Degrees or so.
So after flying around up and down I turn 90 or more and my horizon is way off, cant re calibrate in the air and the straighten function pretty clunky and I'm not sure it works well.
not major things fellas, but any tips much appreciated.
Dave
2. 4K files.
Dave
