[00040789][08 00][00] device not detected issue
Sounds like what I need... no chance you guys are in South Africa ? :) Which part of the drone is it, just the camera (lens/body) ? or the entire gimbal? Trying to figure out how I would do this
The camera is part of the gimbal, it'll be the whole gimbal/camera assembly
Pretty much identical circumstance to me, haven't used my P3P for a while, opened app and 'forced' to update and now my drone doesn't stream images anymore :(
Has anyone figured something out that could fix this? My P3P is out of warranty but this seems like a recall issue, firmware updates shouldn't destroy drones :)
Other then an annoying message that pops up, there is no such action as being forced to perform a update. You might check to see if rolling the firmware back is an option for you.
Nope, I couldn't use the app without the firmware update, I could still fly with just the controller though. Granted I was on a pretty old version maybe thats why?
Issue has been 'solved' but not really, I replaced the camera with the help of @Ted4797 and Drone is back up and running as before with a new camera... not ideal fix but better than giving up :)
You have to set either google playstore or itunes to not auto update the dji app. Other then that, there is no forced updating.
So on my P3P I have an intermittent no image / poor image situation. I've flashed the most current FW several times trying to get it to work. After reading this thread I checked the logs. When I check the logs the 15 device not detected is also intermittent. What I mean to say is that some update attempts seem to see it, other updates didn't. I also do not have issue with the 08 device.
Am I sitting on a ticking time bomb?
Hi Guys,
I do have the same issue, error log says:
[00027761][15 00][00] device not detected.
[00040877][08 00][00] device not detected.
I've uploaded the whole log file.
Does this mean there is no other way to get it work than to have the whole gimbal replaced? How do you think I can manage that from Hungary? I'm pretty hopeless... :(
Thx,
Bálint
All these posts about the 15 00 and 08 00 errors always draw a blank, surely someone somewhere has just replaced the board or does an exchange camera/gimbal assembly?
I should have posted, I replaced my camera unit and the error went away. Couldn't find any other solution that worked.
As I stated in my earlier reply:
Just had the same thing happen to mine. £300 for a new 4k Pro camera/gimbal.
Poor DJI design I guess.
I've bought an Inspire 1 since as the P3P just proved too unreliable.
transmitter burned out. common issue on P3P gimbals. doesn't happen on P3A because they don't overheat and that little fan on top of the aluminum case ain't doing sh**.
it's there for cosmetic appearance :)
basically you had it on too long and it overheated. it happens to people all the time doing firmware upgrades without having a cooling fan bowing at full speed at the
phantom while the upgrade is being applied (20-30 minutes) and the transmitter inside simply burns out.
poor design. well it's DJI ;)
Hi Hunch,
I have a P3A and am running into the same issue. I updated the firmware, the drone flew fine 1 or 2 times and then after that all I see is "No Image Transmission Signal." I talked to DJI support a few different times and concluded that the best thing to do would be to wait for a new update to be released. Needless to say... the drone has been sitting in its case for a couple of months now :\ Do you have any advice?
Hello guys,
I'm with the same problem, after an upgrade the aircraft flew for 10 min and the image transmission failed. I have tried to upgrade, downgrade with the P3X_FW_DEBUG file and I have disasembled the aircraft just in case that it was a wiring problem. None have solved the problem :(
I have been reading this post and I'm convinced that is the same problem with the gimbal mainboard. Do you know if is any possibility of buying only that mainboard and not all the gimbal?
I was really happy with my aircraft but after seeing this silly design (the fan is not doing anything in the gimbal), I'm really disapointed and the most important thing is that they are not offering any help... only send us your drone and we'll charge you £500!
This is my log, just in case that it helps.
[00014293]Packet [C:\P3X_FW_V01.08.0080.bin] resumed, card sn [0x01398ae5].
[00014387]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014462]Version checking[2]...
[00014588][03 05][00] v34.2.0.9 -> v34.2.0.9 need upgrade.
[00014708][03 06][00] v2.4.14.5 -> v2.4.14.5 need upgrade.
[00014797][04 00][00] v1.44.0.0 -> v1.44.0.0 need upgrade.
[00014947][11 00][00] v1.7.15.1 -> v1.7.15.1 need upgrade.
[00015082][12 00][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015243][12 01][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015376][12 02][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00015502][12 03][00] v1.10.0.0 -> v1.10.0.0 need upgrade.
[00028083][15 00][00] device not detected.
[00028243][17 00][00] v1.1.1.7 -> v1.1.1.7 need upgrade.
[00028393][17 01][00] v1.0.2.7 -> v1.0.2.7 need upgrade.
[00028493][19 00][00] v1.0.8.96 -> v1.0.8.96 need upgrade.
[00028568][01 00][05] v1.30.5036 -> v1.30.5036 need upgrade
[00028641][01 01][00] v1.30.5036 -> v1.30.5036 need upgrade
[00041217][08 00][00] device not detected.
[00041313][09 00][00] v3.0.0.10 -> v3.0.0.10 need upgrade.
[00041393]Done.
[00041462]Firmware upgrading[2]...
[00041645][01 01] Firmware upgrade start...
[00071952][01 01] Firmware upgrade finished successfully.
[00072046][12 00] Firmware upgrade start...
[00137838][12 00] Firmware upgrade finished successfully.
[00137935][12 01] Firmware upgrade start...
[00196327][12 01] Firmware upgrade finished successfully.
[00196415][12 02] Firmware upgrade start...
[00259433][12 02] Firmware upgrade finished successfully.
[00259523][12 03] Firmware upgrade start...
[00318490][12 03] Firmware upgrade finished successfully.
[00318589][17 00] Firmware upgrade start...
[00399999][17 00] Firmware upgrade finished successfully.
[00400088][17 01] Firmware upgrade start...
[00464015][17 01] Firmware upgrade finished successfully.
[00464102][11 00] Firmware upgrade start...
[00509828][11 00] Firmware upgrade finished successfully.
[00509913][03 05] Firmware upgrade start...
[00585184][03 05] Firmware upgrade finished successfully.
[00585462][03 06] Firmware upgrade start...
[00902382][03 06] Firmware upgrade finished successfully.
[00905338][19 00] Firmware upgrade start...
[00915718][19 00] stop streaming timeout, continue upgrade.
[01066157][19 00] start streaming timeout, continue upgrade.
[01096238][19 00] Firmware upgrade finished successfully.
[01096336][09 00] Firmware upgrade start...
[01148443][09 00] Firmware upgrade finished successfully.
[01148548][04 00] Firmware upgrade start...
[01206747][04 00] Firmware upgrade finished successfully.
[01206822]Done.
[01206902]Version checking[3]...
[01207013][03 05][05] v34.2.0.9 -> v34.2.0.9 need upgrade.
[01207113][03 06][05] v2.4.14.5 -> v2.4.14.5 need upgrade.
[01207244][04 00][05] v1.44.0.0 -> v1.44.0.0 need upgrade.
[01207392][11 00][05] v1.7.15.1 -> v1.7.15.1 need upgrade.
[01207506][12 00][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01207633][12 01][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01207742][12 02][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01207866][12 03][05] v1.10.0.0 -> v1.10.0.0 need upgrade.
[01220444][15 00][00] device not detected.
[01220582][17 00][05] v1.1.1.7 -> v1.1.1.7 need upgrade.
[01220758][17 01][05] v1.0.2.7 -> v1.0.2.7 need upgrade.
[01220849][19 00][05] v1.0.8.96 -> v1.0.8.96 need upgrade.
[01220923][01 00][05] v1.30.5036 -> v1.30.5036 need upgrade
[01220999][01 01][05] v1.30.5036 -> v1.30.5036 need upgrade
[01233582][08 00][00] device not detected.
[01233695][09 00][05] v3.0.0.10 -> v3.0.0.10 need upgrade.
[01233770]Packet upgrade failed at version checking.
Many thanks in advance,
Enrique
Hello guys,
[00041393]Done.
[01206822]Done.
Enrique
Hi Enrique,
Yes, I had the exact same issue. In Hungary there is a store which deals with repairing Phantom drones. I took it there and they changed the gimbal only as they had one left from an Advanced version. So now I have a Phantom 3 Pro (original camera) but with an Advanced gimbal, which means that basically the image is "only" captured in 2.7K, instead of 4K. I can live with it...
So if you have a local repair store, I'd suggest taking your DJI there as they might have spare parts. Otherwise you can buy the whole gimbal+camera originally from DJI, but that costs around 350 Euros... The repair for me was like 80E.
Lessons learnt is that the gimbal can overheat itself during upgrade, therefore I probably will never do it again at home. No worth... I'll just simply take it to the store and let them do it for 30E.
Sorry to hear your story, but pls. keep us updated!
Bálint
Ok, now that I'm fully reading my log I'm confused... sometimes it shows as upgraded and sometimes as in need upgrade, and sometimes as in not detected... I'll just paste the whole **** log :)
[00014234][01 00] Firmware upgrade finished successfully.
[00014338]Done.
[00014367]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0x00fc997c].
[00014398]Version checking[2]...
[00014479][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00014539][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00014575][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00014628][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014719][11 00][00] v1.6.0.0 -> v1.6.0.0
[00014789][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014854][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014920][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014994][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015108][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015189][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00015289][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00015329][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00015359][01 00][05] v1.15.3056 -> v1.15.3056
[00015389][01 01][00] v1.6.2736 -> v1.15.3056 need upgrade
[00015434][08 00][00] v0.11.0.4 -> v0.11.0.4
[00015461]Done.
[00015490]Firmware upgrading[2]...
[00015628][01 01] Firmware upgrade start...
[00045864][01 01] Firmware upgrade finished successfully.
[00045919][17 00] Firmware upgrade start...
[00165412][17 00] Firmware upgrade finished successfully.
[00165452][17 01] Firmware upgrade start...
[00225498][17 01] Firmware upgrade finished successfully.
[00225541][03 05] Firmware upgrade start...
[00296902][03 05] Firmware upgrade finished successfully.
[00297108][03 06] Firmware upgrade start...
[00602411][03 06] Firmware upgrade finished successfully.
[00605166][19 00] Firmware upgrade start...
[00770895][19 00] Firmware upgrade finished successfully.
[00770952][04 00] Firmware upgrade start...
[00828023][04 00] Firmware upgrade finished successfully.
[00828052]Done.
[00828081]Version checking[3]...
[00828157][03 05][05] v34.2.0.9 -> v34.2.0.9
[00828217][03 06][05] v2.2.6.8 -> v2.2.6.8
[00828292][04 00][05] v1.38.0.0 -> v1.38.0.0
[00828353][09 00][00] v1.7.0.3 -> v1.7.0.3
[00828557][11 00][00] v1.6.0.0 -> v1.6.0.0
[00828648][12 00][00] v1.8.0.0 -> v1.8.0.0
[00828737][12 01][00] v1.8.0.0 -> v1.8.0.0
[00828837][12 02][00] v1.8.0.0 -> v1.8.0.0
[00828923][12 03][00] v1.8.0.0 -> v1.8.0.0
[00829047][15 00][00] v1.1.2.0 -> v1.1.2.0
[00829123][17 00][05] v1.1.1.6 -> v1.1.1.6
[00829243][17 01][05] v1.0.2.5 -> v1.0.2.5
[00829293][19 00][05] v1.0.8.96 -> v1.0.8.96
[00829322][01 00][05] v1.15.3056 -> v1.15.3056
[00829351][01 01][05] v1.15.3056 -> v1.15.3056
[00829389][08 00][00] v0.11.0.4 -> v0.11.0.4
[00829417]Packet upgrade finish successfully.
[00012447]========== remo-con disconnect. boot(15) ============
[00012481]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x80ce35af].
[00012513]Packet upgrade start...
[00012548]Packet checking...
[00012581]Done.
[00012611]Version checking[1]...
[00012684][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012744][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012781][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012829][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012940][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013020][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013099][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013174][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013254][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013371][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013430][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013529][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013589][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013620][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00013659][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00013696][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00013729]Done.
[00015760]Waiting for user confirm...
[00025791]Timeout, start upgrade automatically.
[00025858]Firmware upgrading[1]...
[00038026][01 00] Firmware upgrade start...
[00012229][01 00] Firmware upgrade finished successfully.
[00012270]Done.
[00012301]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x80ce35af].
[00012424]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012487]Version checking[2]...
[00012551][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012625][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012663][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012714][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012826][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00012904][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012980][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013055][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013151][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013277][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013355][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013480][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013535][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013572][01 00][05] v1.23.3419 -> v1.23.3419
[00013602][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00013656][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00013689]Done.
[00013721]Firmware upgrading[2]...
[00013868][01 01] Firmware upgrade start...
[00044119][01 01] Firmware upgrade finished successfully.
[00044978][08 00] Firmware upgrade start...
[00013025]========== remo-con disconnect. boot(15) ============
[00013055]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x80ce35af].
[00013088]Packet upgrade start...
[00013126]Packet checking...
[00013182]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013244]Done.
[00013278]Version checking[1]...
[00013349][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013402][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00013441][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00013493][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013608][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013682][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013778][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013856][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013948][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014069][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014137][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014337][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014392][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014426][01 00][00] v1.23.3419 -> v1.23.3419
[00014456][01 01][00] v1.23.3419 -> v1.23.3419
[00014502][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014539]Done.
[00016571]Waiting for user confirm...
[00026603]Timeout, start upgrade automatically.
[00026669]Firmware upgrading[1]...
[00027447][08 00] Firmware upgrade start...
[00562663][08 00] Firmware upgrade finished successfully.
[00562717][17 00] Firmware upgrade start...
[00605256][17 00] Firmware upgrade finish failed (step = 2, err = 0xaa).
[00635308][17 01] Firmware upgrade start...
[00695351][17 01] Firmware upgrade finished successfully.
[00695400][11 00] Firmware upgrade start...
[00742964][11 00] Firmware upgrade finished successfully.
[00743160][03 06] Firmware upgrade start...
[01046810][03 06] Firmware upgrade finished successfully.
[01046866][04 00] Firmware upgrade start...
[01104519][04 00] Firmware upgrade finished successfully.
[01104554]Done.
[01104586]Version checking[2]...
[01104664][03 05][00] v34.2.0.9 -> v34.2.0.9
[01104743][03 06][05] v2.2.6.19 -> v2.2.6.19
[01104787][04 00][05] v1.40.0.0 -> v1.40.0.0
[01104844][09 00][00] v1.7.0.3 -> v1.7.0.3
[01104963][11 00][05] v1.7.0.0 -> v1.7.0.0
[01105045][12 00][00] v1.8.0.0 -> v1.8.0.0
[01105135][12 01][00] v1.8.0.0 -> v1.8.0.0
[01105218][12 02][00] v1.8.0.0 -> v1.8.0.0
[01105298][12 03][00] v1.8.0.0 -> v1.8.0.0
[01105463][15 00][00] v1.1.2.0 -> v1.1.2.0
[01105535][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[01105653][17 01][05] v1.0.2.7 -> v1.0.2.7
[01105704][19 00][00] v1.0.8.96 -> v1.0.8.96
[01105736][01 00][00] v1.23.3419 -> v1.23.3419
[01105773][01 01][00] v1.23.3419 -> v1.23.3419
[01105814][08 00][05] v0.12.0.4 -> v0.12.0.4
[01105848]Done.
[01105879]Firmware upgrading[2]...
[01105942][17 00] Firmware upgrade start...
[01222014][17 00] Firmware upgrade finished successfully.
[01222046]Done.
[01222165]Version checking[3]...
[01222230][03 05][00] v34.2.0.9 -> v34.2.0.9
[01222323][03 06][05] v2.2.6.19 -> v2.2.6.19
[01222372][04 00][05] v1.40.0.0 -> v1.40.0.0
[01222431][09 00][00] v1.7.0.3 -> v1.7.0.3
[01222556][11 00][05] v1.7.0.0 -> v1.7.0.0
[01222646][12 00][00] v1.8.0.0 -> v1.8.0.0
[01222724][12 01][00] v1.8.0.0 -> v1.8.0.0
[01222812][12 02][00] v1.8.0.0 -> v1.8.0.0
[01222901][12 03][00] v1.8.0.0 -> v1.8.0.0
[01223025][15 00][00] v1.1.2.0 -> v1.1.2.0
[01223121][17 00][05] v1.1.1.7 -> v1.1.1.7
[01223246][17 01][05] v1.0.2.7 -> v1.0.2.7
[01223291][19 00][00] v1.0.8.96 -> v1.0.8.96
[01223325][01 00][00] v1.23.3419 -> v1.23.3419
[01223360][01 01][00] v1.23.3419 -> v1.23.3419
[01223406][08 00][05] v0.12.0.4 -> v0.12.0.4
[01223441]Packet upgrade finish successfully.
[00012467]========== remo-con disconnect. boot(15) ============
[00012501]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x80ce35af].
[00012536]Packet upgrade start...
[00012573]Packet checking...
[00012610]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012644]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012677]Done.
[00012707]Version checking[1]...
[00012785][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012860][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00012899][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00012960][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013085][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013178][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013278][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013365][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013465][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013591][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013690][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013812][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013860][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013891][01 00][00] v1.23.3419 -> v1.23.3419
[00013930][01 01][00] v1.23.3419 -> v1.23.3419
[00013981][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014015]Done.
[00016122]Waiting for user confirm...
[00026158]Timeout, start upgrade automatically.
[00026236]Firmware upgrading[1]...
[00026290][12 00] Firmware upgrade start...
[00092820][12 00] Firmware upgrade finished successfully.
[00092875][12 01] Firmware upgrade start...
[00158065][12 01] Firmware upgrade finished successfully.
[00158115][12 02] Firmware upgrade start...
[00223483][12 02] Firmware upgrade finished successfully.
[00223535][12 03] Firmware upgrade start...
[00292393][12 03] Firmware upgrade finished successfully.
[00292611][03 06] Firmware upgrade start...
[00604878][03 06] Firmware upgrade finished successfully.
[00604944][04 00] Firmware upgrade start...
[00663903][04 00] Firmware upgrade finished successfully.
[00663940]Done.
[00663972]Version checking[2]...
[00664063][03 05][00] v34.2.0.9 -> v34.2.0.9
[00664143][03 06][05] v2.3.0.13 -> v2.3.0.13
[00664182][04 00][05] v1.41.0.0 -> v1.41.0.0
[00664283][09 00][00] v1.7.0.3 -> v1.7.0.3
[00664409][11 00][00] v1.7.0.0 -> v1.7.0.0
[00664518][12 00][05] v1.10.0.0 -> v1.10.0.0
[00664624][12 01][05] v1.10.0.0 -> v1.10.0.0
[00664724][12 02][05] v1.10.0.0 -> v1.10.0.0
[00664822][12 03][05] v1.10.0.0 -> v1.10.0.0
[00664962][15 00][00] v1.1.2.0 -> v1.1.2.0
[00665052][17 00][00] v1.1.1.7 -> v1.1.1.7
[00665173][17 01][00] v1.0.2.7 -> v1.0.2.7
[00665263][19 00][00] v1.0.8.96 -> v1.0.8.96
[00665300][01 00][00] v1.23.3419 -> v1.23.3419
[00665337][01 01][00] v1.23.3419 -> v1.23.3419
[00665382][08 00][00] v0.12.0.4 -> v0.12.0.4
[00665423]Packet upgrade finish successfully.
[00012490]========== remo-con disconnect. boot(15) ============
[00012525]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x80ce35af].
[00012560]Packet upgrade start...
[00012604]Packet checking...
[00012640]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012676]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012709]Done.
[00012747]Version checking[1]...
[00012835][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012989][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013036][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013088][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013208][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013330][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013413][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013503][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013583][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013722][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013794][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013929][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013989][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014023][01 00][00] v1.23.3419 -> v1.23.3419
[00014057][01 01][00] v1.23.3419 -> v1.23.3419
[00014111][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014149]Done.
[00016184]Waiting for user confirm...
[00026228]Timeout, start upgrade automatically.
[00026301]Firmware upgrading[1]...
[00026344][11 00] Firmware upgrade start...
[00073943][11 00] Firmware upgrade finished successfully.
[00073984]Done.
[00074021]Version checking[2]...
[00074094][03 05][00] v34.2.0.9 -> v34.2.0.9
[00074174][03 06][00] v2.3.0.13 -> v2.3.0.13
[00074216][04 00][00] v1.41.0.0 -> v1.41.0.0
[00074312][09 00][00] v1.7.0.3 -> v1.7.0.3
[00074436][11 00][05] v1.7.0.0 -> v1.7.0.0
[00074527][12 00][00] v1.10.0.0 -> v1.10.0.0
[00074603][12 01][00] v1.10.0.0 -> v1.10.0.0
[00074703][12 02][00] v1.10.0.0 -> v1.10.0.0
[00074807][12 03][00] v1.10.0.0 -> v1.10.0.0
[00074957][15 00][00] v1.1.2.0 -> v1.1.2.0
[00075038][17 00][00] v1.1.1.7 -> v1.1.1.7
[00075158][17 01][00] v1.0.2.7 -> v1.0.2.7
[00075213][19 00][00] v1.0.8.96 -> v1.0.8.96
[00075249][01 00][00] v1.23.3419 -> v1.23.3419
[00075283][01 01][00] v1.23.3419 -> v1.23.3419
[00075333][08 00][00] v0.12.0.4 -> v0.12.0.4
[00075370]Packet upgrade finish successfully.
[00016142]========== remo-con disconnect. boot(15) ============
[00016260]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x80ce35af].
[00016366]Packet upgrade start...
[00016515]Packet checking...
[00016734]Packet vlink 01.09.0060 <-> 01.08.0080.
[00016834]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00016919]Done.
[00017028]Version checking[1]...
[00017181][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017325][03 06][00] v2.3.0.13 -> v2.4.20.18 need upgrade.
[00017452][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00017640][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00017846][11 01][00] v1.7.0.0 -> v2.0.0.33 need upgrade.
[00017993][12 00][00] v1.10.0.0 -> v1.10.0.0
[00018173][12 01][00] v1.10.0.0 -> v1.10.0.0
[00018353][12 02][00] v1.10.0.0 -> v1.10.0.0
[00018533][12 03][00] v1.10.0.0 -> v1.10.0.0
[00031142][15 00][00] device not detected.
[00031310][17 00][00] v1.1.1.7 -> v1.1.1.7
[00031529][17 01][00] v1.0.2.7 -> v1.0.2.7
[00031666][19 00][00] v1.0.8.96 -> v1.0.8.96
[00031744][01 00][00] v1.23.3419 -> v1.30.5036 need upgrade
[00031856][01 01][00] v1.23.3419 -> v1.30.5036 need upgrade
[00044465][08 00][00] device not detected.
[00044605][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00044753]Done.
[00046866]Waiting for user confirm...
[00056974]Timeout, start upgrade automatically.
[00057117]Firmware upgrading[1]...
[00069188][01 00] Firmware upgrade start...
[00014226][01 00] Firmware upgrade finished successfully.
[00014273]Done.
[00014309]Packet [C:\P3X_FW_V01.09.0060.bin] resumed, card sn [0x80ce35af].
[00014351]Packet vlink 01.09.0060 <-> 01.08.0080.
[00014387]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014432]Version checking[2]...
[00014508][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014588][03 06][00] v2.3.0.13 -> v2.4.20.18 need upgrade.
[00014638][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00014753][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00014868][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00014906][11 01][00] v1.7.0.0 -> v2.0.0.33
[00014996][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015076][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015161][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015355][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027895][15 00][00] device not detected.
[00027977][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028122][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028172][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028208][01 00][05] v1.30.5036 -> v1.30.5036
[00028245][01 01][00] v1.23.3419 -> v1.30.5036 need upgrade
[00040789][08 00][00] device not detected.
[00040853][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00040888]Done.
[00040922]Firmware upgrading[2]...
[00041066][01 01] Firmware upgrade start...
[00071325][01 01] Firmware upgrade finished successfully.
[00071375][11 00] Firmware upgrade start...
[00117928][11 00] Firmware upgrade finished successfully.
[00118183][03 06] Firmware upgrade start...
[00491828][03 06] Firmware upgrade finished successfully.
[00491886][09 00] Firmware upgrade start...
[00549811][09 00] Firmware upgrade finished successfully.
[00549873][04 00] Firmware upgrade start...
[00608056][04 00] Firmware upgrade finished successfully.
[00608093]Done.
[00608130]Version checking[3]...
[00608199][03 05][00] v34.2.0.9 -> v34.2.0.9
[00608299][03 06][05] v2.4.20.18 -> v2.4.20.18
[00608353][04 00][05] v1.44.0.0 -> v1.44.0.0
[00608459][11 00][05] v1.8.0.0 -> v1.8.0.0
[00608579][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00608620][11 01][00] v1.8.0.0 -> v2.0.0.33
[00608721][12 00][00] v1.10.0.0 -> v1.10.0.0
[00608803][12 01][00] v1.10.0.0 -> v1.10.0.0
[00608900][12 02][00] v1.10.0.0 -> v1.10.0.0
[00608985][12 03][00] v1.10.0.0 -> v1.10.0.0
[00621529][15 00][00] device not detected.
[00621605][17 00][00] v1.1.1.7 -> v1.1.1.7
[00621730][17 01][00] v1.0.2.7 -> v1.0.2.7
[00621785][19 00][00] v1.0.8.96 -> v1.0.8.96
[00621827][01 00][05] v1.30.5036 -> v1.30.5036
[00621869][01 01][05] v1.30.5036 -> v1.30.5036
[00634405][08 00][00] device not detected.
[00634468][09 00][05] v3.0.0.10 -> v3.0.0.10
[00634503]Packet upgrade failed at version checking.
[00014612]========== remo-con disconnect. boot(15) ============
[00014738]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x80ce35af].
[00014781]Packet upgrade start...
[00014832]Packet checking...
[00014879]Packet vlink 01.09.0060 <-> 01.08.0080.
[00014925]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014969]Done.
[00015011]Version checking[1]...
[00015110][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015190][03 06][00] v2.4.20.18 -> v2.4.20.18
[00015244][04 00][00] v1.44.0.0 -> v1.44.0.0
[00015368][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015488][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015538][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015648][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015738][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015837][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015939][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028481][15 00][00] device not detected.
[00028573][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028721][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028789][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028831][01 00][00] v1.30.5036 -> v1.30.5036
[00028881][01 01][00] v1.30.5036 -> v1.30.5036
[00041426][08 00][00] device not detected.
[00041489][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041533]Packet upgrade failed at version checking.
[00014551]========== 2016.11.01 18:12:49. boot(15) ============
[00014597]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x80ce35af].
[00014640]Packet upgrade start...
[00014693]Packet checking...
[00014735]Packet vlink 01.09.0060 <-> 01.08.0080.
[00014785]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014830]Done.
[00014871]Version checking[1]...
[00014941][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015021][03 06][00] v2.4.20.18 -> v2.4.20.18
[00015071][04 00][00] v1.44.0.0 -> v1.44.0.0
[00015201][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015341][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015385][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015490][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015681][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015764][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015861][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028406][15 00][00] device not detected.
[00028505][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028625][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028685][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028732][01 00][00] v1.30.5036 -> v1.30.5036
[00028781][01 01][00] v1.30.5036 -> v1.30.5036
[00041326][08 00][00] device not detected.
[00041387][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041433]Packet upgrade failed at version checking.
[00101602]========== 2016.11.01 18:57:48. boot(15) ============
[00101651]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x80ce35af].
[00101695]Packet upgrade start...
[00101746]Packet checking...
[00101791]Packet vlink 01.09.0060 <-> 01.08.0080.
[00101840]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00101888]Done.
[00101933]Version checking[1]...
[00102021][03 05][00] v34.2.0.9 -> v34.2.0.9
[00102119][03 06][00] v2.4.20.18 -> v2.4.20.18
[00102168][04 00][00] v1.44.0.0 -> v1.44.0.0
[00102304][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00102439][11 01][00] v1.7.0.0 -> v2.0.0.33, firmware v1.7.0.0 not support.
[00102484][11 01][00] v1.7.0.0 -> v2.0.0.33
[00102588][12 00][00] v1.10.0.0 -> v1.10.0.0
[00102689][12 01][00] v1.10.0.0 -> v1.10.0.0
[00102789][12 02][00] v1.10.0.0 -> v1.10.0.0
[00102889][12 03][00] v1.10.0.0 -> v1.10.0.0
[00115433][15 00][00] device not detected.
[00115527][17 00][00] v1.1.1.7 -> v1.1.1.7
[00115666][17 01][00] v1.0.2.7 -> v1.0.2.7
[00115721][19 00][00] v1.0.8.96 -> v1.0.8.96
[00115764][01 00][00] v1.30.5036 -> v1.30.5036
[00115810][01 01][00] v1.30.5036 -> v1.30.5036
[00128357][08 00][00] device not detected.
[00128421][09 00][00] v3.0.0.10 -> v3.0.0.10
[00128465]Done.
[00130509]Waiting for user confirm...
[00140553]Timeout, start upgrade automatically.
[00140640]Firmware upgrading[1]...
[00140698][11 00] Firmware upgrade start...
[00187656][11 00] Firmware upgrade finished successfully.
[00187771]Done.
[00187818]Version checking[2]...
[00187906][03 05][00] v34.2.0.9 -> v34.2.0.9
[00188007][03 06][00] v2.4.20.18 -> v2.4.20.18
[00188065][04 00][00] v1.44.0.0 -> v1.44.0.0
[00188182][11 00][05] v1.8.0.0 -> v1.8.0.0
[00188341][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00188388][11 01][00] v1.8.0.0 -> v2.0.0.33
[00188490][12 00][00] v1.10.0.0 -> v1.10.0.0
[00188590][12 01][00] v1.10.0.0 -> v1.10.0.0
[00188696][12 02][00] v1.10.0.0 -> v1.10.0.0
[00188796][12 03][00] v1.10.0.0 -> v1.10.0.0
[00201350][15 00][00] device not detected.
[00201449][17 00][00] v1.1.1.7 -> v1.1.1.7
[00201568][17 01][00] v1.0.2.7 -> v1.0.2.7
[00201623][19 00][00] v1.0.8.96 -> v1.0.8.96
[00201664][01 00][00] v1.30.5036 -> v1.30.5036
[00201713][01 01][00] v1.30.5036 -> v1.30.5036
[00214259][08 00][00] device not detected.
[00214321][09 00][00] v3.0.0.10 -> v3.0.0.10
[00214367]Packet upgrade failed at version checking.
[00012570]========== remo-con disconnect. boot(15) ============
[00012618]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x80ce35af].
[00012666]Packet upgrade start...
[00012712]Packet checking...
[00012757]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012804]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012849]Done.
[00012892]Version checking[1]...
[00012962][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013038][03 06][00] v2.4.20.18 -> v2.4.20.18
[00013086][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013219][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013362][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013405][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013512][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013612][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013712][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013812][12 03][00] v1.10.0.0 -> v1.10.0.0
[00026358][15 00][00] device not detected.
[00026447][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026571][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026733][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026784][01 00][00] v1.30.5036 -> v1.30.5036
[00026829][01 01][00] v1.30.5036 -> v1.30.5036
[00039373][08 00][00] device not detected.
[00039433][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039478]Packet upgrade failed at version checking.
[00015587]========== remo-con disconnect. boot(15) ============
[00015638]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x80ce35af].
[00015682]Packet upgrade start...
[00015733]Packet checking...
[00015785]Packet vlink 01.09.0060 <-> 01.08.0080.
[00015831]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015875]Done.
[00015921]Version checking[1]...
[00015999][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016079][03 06][00] v2.4.20.18 -> v2.4.20.18
[00016141][04 00][00] v1.44.0.0 -> v1.44.0.0
[00016264][11 00][00] v1.8.0.0 -> v1.8.0.0
[00016379][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00016422][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016512][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016588][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016688][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016768][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029311][15 00][00] device not detected.
[00029406][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029530][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029590][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029643][01 00][00] v1.30.5036 -> v1.30.5036
[00029688][01 01][00] v1.30.5036 -> v1.30.5036
[00042234][08 00][00] device not detected.
[00042309][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042355]Packet upgrade failed at version checking.
[00012579]========== remo-con disconnect. boot(15) ============
[00012634]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x80ce35af].
[00012675]Packet upgrade start...
[00012727]Packet checking...
[00012777]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012826]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012870]Done.
[00012912]Version checking[1]...
[00012998][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013138][03 06][00] v2.4.20.18 -> v2.4.20.18
[00013191][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013324][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013438][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013483][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013568][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013664][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013764][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013847][12 03][00] v1.10.0.0 -> v1.10.0.0
[00026396][15 00][00] device not detected.
[00026514][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026648][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026713][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026757][01 00][00] v1.30.5036 -> v1.30.5036
[00026808][01 01][00] v1.30.5036 -> v1.30.5036
[00039354][08 00][00] device not detected.
[00039417][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039468]Packet upgrade failed at version checking.
[00014988]========== remo-con disconnect. boot(15) ============
[00015048]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xc1ee02ee].
[00015104]Packet upgrade start...
[00015171]Packet checking...
[00015228]Packet vlink 01.09.0060 <-> 01.08.0080.
[00015284]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015342]Done.
[00015402]Version checking[1]...
[00015486][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015586][03 06][00] v2.4.20.18 -> v2.4.20.18
[00015649][04 00][00] v1.44.0.0 -> v1.44.0.0
[00015806][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015928][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015983][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016096][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016200][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016300][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016424][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028979][15 00][00] device not detected.
[00029096][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029266][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029342][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029403][01 00][00] v1.30.5036 -> v1.30.5036
[00029458][01 01][00] v1.30.5036 -> v1.30.5036
[00042111][08 00][00] device not detected.
[00042182][09 00][00] v3.0.0.10 -> v3.0.0.10
[00042242]Packet upgrade failed at version checking.​
Having the same problem and trying to diagnose. How did you download those logs?
Drone Sky Hook
