Wire Diagram Specs.
Coachella Valley
Hey evert body,
My question is where can I go to find a wire diagram that shows details specifically for those wires leading to the gimbal on Phantom3_4K...… Reason is I removed the entire gimbal & replaced with an aftermarket bracket that holds a fixed camera. Instead of using an external power source I want to tap into the drones power that supplies the OEM gimbal...Before I sign off I hope you all had a peaceful Christmas and I pray you all have a great New Years....Cheers
From memory the power ribbon pins 1 to 4 are ground with 7 to 10 being +12V DC. Very easy to test with a multimeter and powered up AC.
I did come across this image that displays you're saying but also do you have any ideas where I can find the connections needed to deliver power
Reactions: FlyB0y03
apktuti
