- Joined
- Dec 7, 2013
- Messages
- 1,206
- Reaction score
- 136
FlyingFox said:Anyone know a UK supplier of the Sunhans amp?
You can use ebay.
J Dot said:Hello,
I found a guy who built this:
( over 4,000 feet range ) my stock P2V is 514 feet for FPV.
Here is a parts list and pictures:
I'm into a new project now, a range extender mod with 2 antennas and a wifi booster, will have its own power pack, ect. Will cost around $500. Sits on a large tripod ( outdoor RV portable antenna pole/stand ( approx 7' tall ) I'm using
1) 2x tp-link ( tl-ant2414b ) antennas ( $60 each ) appox price
2) DJI wifi range extender ( spare so I don't mess mine up ( lol ) ( $40 - $60 )
3) sunmans ( sh24gi1000-d2 ) wifi 2.4ghz amplifier / booster ( dual antenna ) ( $100 )
4) 2x UF.l mini PCI to RP-SMA pigtail cables. ( $8 ) both
5) USB multi port power bank ( 20,000 mah ) 12-19v ( $100-150 )
6) RV portable antenna pole. ( $40 )
7) misc. mounts, hardware, cable ties, ect. ( for mounting everything to pole )
( range of more than 4,000 feet ( I only get 514 ft stock ) then I loose FPV
( I want to fly above the clouds on a really cloudy day, for some sweet footage.
Picture:
And I want to upgrade controller with this antenna:
Picture:
This is one of the best setups I've seen, not too expensive, but excellent range! Not sure what kind of range I will get on trams with new antenna? But will post updates when I figure it out!
Jerry D.
USA
( J Dot )
FlyingFox said:Just ordered these after Bens great video , I think they should be okay, the amp is a sunhans
BenDronePilot said:FlyingFox said:Just ordered these after Bens great video , I think they should be okay, the amp is a sunhans
Thanks glad you enjoyed my bid. That looks like the 2watt Sunhans amp I got from amazon, tho it doesn't have the Sunhans label. I'm sure its fine tho you'll be loving your range increase.
J Dot said:( over 4,000 feet range ) my stock P2V is 514 feet for FPV.
Jerry D.
USA
( J Dot )
mr_3_0_5 said:Should make it to 10,000 ft with this compact set up
tizzl10 said:mr_3_0_5 said:Should make it to 10,000 ft with this compact set up
hold up..where is your power for the amp?
paulgrenga said:Installed a 4watt amp and a 14db TP-Link Tl-Ant2414A antenna. No increase in FPV range. Clear line of site but FPV ends at 1200' or less. Any ideas?
