Why is maximum flight distance reached but my drone only 20 feet high?
The solution to this mystery will probably be found in your recorded flight data.
Go to DJI Flight Log Viewer | Phantom Help
That will give you a detailed report of the flight.
Or .. just post the txt file here.
Then someone might be able to analyse it and give you an understanding of the cause of the incident.
Reactions: Rick218
What is really your question?
Maximum distance and 20f high? It is completelly normal. Unless you ment maximum HIGHT or altitude?
DJI mini
Flight distance and altitude are two different things and different settings. Distance is horizontal away from controller. Altitude or height is vertical distance from the take off elevation.
Low as I can set mine at is 49.2’ so it
sorry I’m late but just got to power up my Mini but lowest you can
set it is
Check to see if the drone is in "Beginner Mode" . I have had this happen with my P4P and MP . That's where I would start .
I couldn’t find beginners mode looking. But might have missed it.
Also you might want to join our sister forum.
jeetbuzz360
