- Joined
- May 9, 2015
- Messages
- 294
- Reaction score
- 56
- Age
- 72
If you look at the birdThat is odd but sort of cool too.
Obviously, it must use several exposures to achieve a higher dynamic range, but things moving quickly sure give some odd effects.View attachment 91062
Was that the built-in HDR feature?Obviously, it must use several exposures to achieve a higher dynamic range, but things moving quickly sure give some odd effects.View attachment 91062
A better solution is to use AEB bracketing and do your own HDR processing.
Most of the HDR programs like Photomatix automatically recognise and remove ghots or allow you to have control over ghost removal.
That sounds like a good way around it, and yes, that was the built-in HDR. It also takes forever to process & record it - you don't have realtime fpv for about 15 seconds.I learned this from @Meta4 and it's been awesome. We now shoot almost everything in AEB (3 or more) and once in a while we have to delete a frame or two but more often than not it's the key to an amazing shot.
This is why AEB is the way to go. You do the processing/combining of images later at your leisure.That sounds like a good way around it, and yes, that was the built-in HDR. It also takes forever to process & record it - you don't have realtime fpv for about 15 seconds.
