- Joined
- Feb 4, 2014
- Messages
- 301
- Reaction score
- 22
Re: Wish I knew...
Yeah that sucks.Mine fell out for a different reason but it sucks not knowing if its going to do it again and your scared to fly it over anything
robschoemaker said:My last crash, the Phantom just shutdown in mid air and plummeted from the sky. I just finished all the repairs (replacement landing gear, camera mount, etc).
My initial analysis was that it has to be one of the following, since all 4 motors stopped at the same time (actually it fell down perfectly horizontal, so all motors must have stopped simultaneously):
- Battery failure
- Main power-leads
- Main board / Naza module
The thing that scares me however is that I have not been able to find the root-cause for the crash. At first I thought it must be a loose wire or something, so I opened up the shell, and looked for any loose wires or bad solder joints, could not find any.
Next I switched on the motors, and used a pincet to "shake" all the wires individually, to see if there is any bad cable etc. No results.
I remembered that prior to the crash, IOC automatically disengaged, which might be the result of a very short interruption of the power, so I put my Phantom in IOC mode and repeated the steps before, hoping that IOC would disengage which would be the indication of a short break in the power. No results.
Next, I just shake my Phantom like it experiencing very bad vibrations, No results.
So I am a little scared to fly again, since I could not find the root cause, so it could happen any time again. For now, I decided not to use the battery that was involved in the crash anymore (maybe it was a battery issue, but I do not have the means to verify that :-(). Also, I will keep an eye on disengaging IOC. And of course be careful where I fly. (not over houses, people, etc).
Regards Rob
