White spot in centre of video when sun is behind me
When I filming with my P3P all is okay. Execept in the following situation:
When I'm filming and the sun is right behind me, there is a light spot in the centre of the frame. When I pan to the left and the right, it disappears. So does anyone know what this is?
Changing video settings make no difference.
I have an example of the issue right here. (right click --> save as, 114MB).
That is a normal optical effect that happens with all cameras. You normally don't see it because you normally aren't taking video with the sun directly behind you.
-- Roger
Roger, haha okay. Yes the sun was low (evening here in Holland right now). So nothing to care :D?
Thanks for the link.
I found it interesting.
It's called a Heiligenschein.
Reactions: rhoffart
Ich danke Ihnen
Thanks. I see why I wasn't able to remember what it is called. :)
-- Roger
It's also called a Glory because of the halo effect if you are looking at your own shadow.
Reactions: RuneW
I will just have to call it a sun spot-- because I cant even pronounce those -- much less remember them. Good to know.
Thanks for sharing.:)
