Have some strangeness going on with a phantom 2 vision I have been trying to repair.
any time I have the motors runing and go to stop the motors using the CLC command by pushing both the sticks down and to the center The motors Rev up rally hard and violently causing the phantom to hop up in the air and flip over. Every time. when starting them they start fine and only seems to do it when trying to shut them off. Only way it dont do it is if I pull the left stick straight down first then the move them both to the bottom center. Then it stops them fine.
But I also noticed when i do it the normal way and it causes the motors to rev up and it flips over. my battery keep poping out and I thought it was from it flipping over. But today I noticed even if I am holding on to it so it cant flip that the battery would pop out every time the motors revved up when trying to stop them. They go for idle to full speed in a slip second and rev up so high it actually is causing the body to flex and is whats causing the battery to pop out about 1/4 inch each time.
This is really starting to vex me and this motor reving to full power any time I try to shut it down is the last issue I need to sort out before I can ever try to test it out more fully.
And being I have brand new motors new escs to even try and rule out if it was the transmitter causing the problem I even tried two other transmitters to my other phantoms and they cause the high rev and flip also when doing the down and center motor stop command.
So any one else have any ideas what the heck can still be wrong??????????
