When I'm using AZ screen recorder I get interference on my screen.
I'm using a Galaxy S Tab with my P4P. If I use AZ screen recorder while using the DJI GO 4 app, I get a lot of scrambling or interference on the screen. If I use it with any other app it works perfectly. I've tried using the different encoding options and have changed the resolution settings in the AZ app, but it seems to make no difference. Any suggestions? Thanks.
You should use perfectly shielded and earthed cable to get min interference. This assumes that the radiation is thru the connecting cable. Not sure if any other item also has leakage.
jeetbuzz360
