What's with the range of these?
It varys from model to model ,where you are at and condition’s.
We have a sister forum you can look at and look at them.
. DJI Mavic Drone Forum
Also for the other models you might look in here also.
Reactions: 3putts
Based on the range numbers listed in that less than accurate article, the word gullible comes to mind.
2.5 miles on a mavic mini? Silly.
Reactions: 3putts
No it’s not.where I am it’s no issue. Like I said before Meta posted
it depends on conditions. But you should know that Starz. What
i find silly with thier #’s is flight time. I have yet with any I have had
last as long as they list.
Reactions: 3putts
So you have a mini that can run 2.5 miles?
If I’m lucky, 1/2 mile. Not a ton of interference in this area.
Reactions: 3putts
Nice place to fly. I have water then nothing but the hills here with cut overs and pine trees. You know I’ve always played with wifi models
and guess I’ve just learned how to milk them.
Pretty sure you having a mini you’ve seen this thread.
I have no knowledge of range on Mavics; I fly a P3P and most of my work is over water in bay, estuary, or a river tracking rowing shells. I use the antenna range extenders which are merely 3D printed plastic covers formed in a half-cylinder that have HVAC reflective tape on them and they slip over the antennas on the Phantom controller. They work GREAT and change the omnidirectional antenna into a unidirectional antenna. You have to keep the controller antennas pointed at the drone but I've gotten over 2 miles with range extenders. With drone in a hover just 50 meters away, if I turn my back on the drone I cannot control it so these work well. I see these are made and offered for the Mavic; Amazon.com: Signal Booster Range Extender for DJI Mavic Mini/Pro/Air/Spark Transmitter Signal Remote Controller Antenna Amplifier Range Extender: Toys & Games
I have no clue about their effectiveness on the MAVIC, but for my P3P they have been extremely effective and completely eliminated problems I had when I was 1500 meters plus out with the aircraft getting control and video signal drop out where the feed comes back all pixelated, jiggity, frozen, black screen. On my controller, they look like this:
I have a P3P and live within 1/2 mile of the ocean. A lot of my flying is from property owned by friends that overlooks the ocean. I have flown out 3.1 miles, could not see the drone and hustled back. The battery was below 50%. Parts on my old body puckered until I heard that familiar sound. Decided to stay within a reasonable range and within sight.
  • Haha
Reactions: dirkclod
I have found with my Phantom 4 that the range varies from where I am flying from. I depends on how much WiFi and 2.4gHz and 5Ghz is in the area. The best I got was 0.75 miles. Also line of site is important. Any man made or natural obstruction can vary the range. The biggest limitation is what how far can you maintain visual contact of your drone!
I came close on a brand new battery but have found that with use, you can pretty much halve their max flight times and it will be right within a minute or two both ways.
Reactions: xmtrdr
Flight time has a lot of variables playing on it. Winds, number of satellites, How fast you are flying, how much you are recording or snapping! I run to about 30% and average about 20 to 24 minutes per battery!
Reactions: R Martin
Here, there is always something conspiring against you. It's either to hot, to cold, or really windy. But as long as you don't fall into a location with a lot of multipathing, the GPS signal is great.
Reactions: xmtrdr
Wind seems to be the biggest where I am. We can't for get the cold in the Winter. I usually put the drone away in the winter! Multipath isn't the biggest issue I get. I run into a lot of WiFi channel traffic!
Reactions: R Martin
I hear you. We can usually get a few flights in almost all the way to Christmas but then the temp drops below my minimums and the winds pick up. Flight in the spring is really challenging depending upon which aircraft I launch. Summer is just months of 100+ heat. With all the Covid-19 problems this year. I am hoping to get my first flight in next week. After that, if it goes well, I'll almost be flying daily until late August.
Flight time has a lot of variables playing on it. number of satellites,
Out of curiosity, how do satellites affect flight time.?
Reactions: Starz
Fimaj
