P3 Firmware what are all the aborts?
Would like to know if my drone was updated to the 4/7 upgrade correctly and also if the date means anything on the last entry on this txt file.
This is the txt file on my memory card
========== 2014.01.01 00:04:28 remo-con disconnect======
Packet: P3S_FW_V01.07.0060.bin
Upgrading ...
Result: Success.
========== 2016.04.01 01:00:14 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.04.01 22:22:02 =====================
Result: Abort.
========== 2016.04.01 23:54:23 =====================
Result: Abort.
========== 2016.04.01 23:59:04 =====================
Result: Abort.
========== 2016.04.02 00:18:21 =====================
Result: Abort.
========== 2016.04.02 15:01:41 =====================
Result: Abort.
========== 2016.04.09 01:46:13 =====================
Result: Abort.
========== 2014.01.01 00:00:10 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:00:09 remo-con disconnect======
Result: Abort.
========== 2016.04.09 01:56:49 =====================
Result: Abort.
Packet: P3S_FW_V01.08.0080.bin
Upgrading ...
Result: Success.
Looking at your log, the firmware upgraded to 1.07 successfully. You kept the .bin file on your sd card so each time you turned your phantom on, it ran the firmware upgrade again only to determine that it was already installed so it aborted. Last entry shows you upgraded to 1.08 successfully.
