Vision system error
Have a Vision system error on the main screen and it isn't working on the aircraft. The aircraft status screen that comes on when I power up the remote says the vision sensors are normal and all sensors are turned on. What do I do, thanks!
In my case with my P4 Pro V 2.0 the video would not work nor would any gimbal movement. Nothing worked video or photo wise. Traced it to a bad SD card. Pulled out bad card and all worked except of course recording. Another card worked 100% as did the bad card after reformatting. I probably did not properly eject the card from my computer and that messed it up.
Might check your card.
Good luck
Jim
WA5TEF
Turn all OA and vps off and turn on again,tryed this,,? Do imu calibration
