Videos Ending Randomly
Hi guys. The last 4 or 5 times I've flown my P3 Std I've had a problem with the video stopping randomly after anywhere from a few seconds to up to 10 minutes or more. I'm using a Class 1 32 GB SanDisk micro chip with lots of open space on it. Could this be caused by the chip?
Yup... I find that this almost always happens when the card is not writing fast enough. If you can, lower the video resolution and see if the problem goes away. If so, the card is not writing fast enough. Not all cards are created equal.
Reactions: RodPad
Write speed is the major factor:
Rated Speed (e.g. 15MB/s, 30MB/s, etc.) is maximum speed of the card and also what you would expect to approximately see in typical usage of writing or reading files on the card. This measurement is pertinent to still photography, especially for taking pictures with high resolution and/or saving in RAW format where the files created are very large. The faster the card, the faster it can save the file and be ready to take another picture. You can really notice speed differences with high-megapixel DSLR cameras when using multi-shot burst mode.
Still digital images shot on high-megapixel cameras should utilize fast data throughput (a large data pipe), higher speed cards for improved performance. Higher speed cards can also improve how fast you can transfer the files to and from the card and your computer.
Speed Class is a minimum speed based on a worst case scenario test. The Speed Class is important for video mode or camcorders, where the device is actually saving a steady stream of data. The resolution and format of the video determines the amount of steady stream data. This translates to a minimum speed you need to guarantee that the video captured on the cards is recorded at an even, sustained rate with no dropped frames (which would result in lost data and choppy playback).
Compared to high-megapixel photography, video doesn't need as big a data pipe because the video format is a smaller "fixed stream" that uses only a portion of the data pipe. But you do need a minimum guaranteed speed for the SDHC card that satisfies the requirement of the data stream. Your camera's specifications should state the minimum SDHC Class Rating required.
Using a card without the proper class rating on a more advanced camera, such as a high-definition (HD) camcorder or Digital Single Lens Reflex (DSLR) camera with HD video record settings is likely to result in an error message indicating that video can only be recorded at a lower definition setting.
The current SDHC specification defines Class 2, 4, 6, 8 and 10 as follows:
Class
Minimum Speed
2MB/s
4
4MB/s
6
6MB/s
8
8MB/s
10
10MB/s
UHS Speed Class was introduced in 2009 by the SD Association and is designed for SDHC and SDXC memory cards. UHS utilizes a new data bus that will not work in non-UHS host devices. If you use a UHS memory card in a non-UHS host, it will default to the standard data bus and use the "Speed Class" rating instead of the "UHS Speed Class" rating. UHS memory cards have a full higher potential of recording real time broadcasts, capturing large-size HD videos and extremely high quality professional HD.
UHS Class
Minimum Speed
10MB/s
3 30MB/s
Video Speed Class or "V Class", was created by the SD Association to identify cards that can handle higher video resolutions and recording features. This speed class guarantees minimum sustained performance for recording video.
The other speed classes are either not optimized or are unable to accommodate the recording of multiple video streams, 360 capture, virtual reality content or 8K and higher resolution video.
V Class
Minimum Sustained Speed
V6
6MB/s
V10
10MB/s
V30
30MB/s
V60
60MB/s
V90
90MB/s
1 1 megabyte (MB) = 1 million bytes
2 Based on SanDisk internal testing; performance may vary depending upon host device.
Reactions: RodPad
@tcope, I agree..
@daknife, Have you changed your settings?
Rod
