Video Transmission Signal Cuts Out
Hello All,
This started the other day and in multiple locations. My Video signal Transmission cuts out completely when flying for a few minutes. Sometimes it comes back, other times it does not. When it does, it resets all the camera settings to factory. If I land it, change battery, leave it sit for a bit, it will usually work for a little bit before cutting out again. It seems like there is a lose connection somewhere as when real close, it cut out and I would jiggle the sticks a bit and it would come back.
Any ideas? I havve one more flight I must complete for a project ASAP.
Thanks!
Might check the setting in "HD", try reducing the size of the video stream.
Power everything up, go into the camera view of the app.
Tap the three dots top right hand corner.
Scroll down to HD settings and tap that.
Scroll down and you should see the slider to adjust your image transmission bit rate.
Trim it down to 4mbps and select a custom channel that is free of interference.
You need to be powered up to see and save these settings. (Thanks, tevek!)
Are you using a Windjammer? If so, is it facing the right way?
Thanks Techcop50. I do not use a Windjammer. I will check the settings, but I have been flying a lot all summer long and have never had this problem. When it cuts out, there is no video at all and I have to fly by radar. It may snap back, but when it does, the camera is way out of wack and my settings all get reset to factory. It will say that there is a malfunction with the camera sensor.[/QUOTE]
