Sweet! I assume that while the overlay is not user selectable, that it doesn't interfere with the DJI OSD Mini display. Looks like it doesn't from the pic. Have you had it out in the sun yet? Brightness OK?Ravecreative said:Just put the monitor on the transmitter
bit of an issue - the monitor seems to have it's own information overlay which you cannot turn off :-(
it is helpful for the battery level, but i'd rather turn it off
still, it's cheap so what can you do
the reception seems to be spot on, and the range isn't bad too
http://www.ravecreative.co.uk/phantom2/photo6.jpg
http://www.ravecreative.co.uk/phantom2/photo7.jpg
http://www.ravecreative.co.uk/phantom2/photo8.jpg
Man, you're makin' me want a 3D printer. Which make and model do you have?Ravecreative said:I'm itching to get it out ( the monitor that is - LOL )
the weather is terrible, so i'm just messing around with the electronics and mountings etc
it seems fairly bright, but the shield is a bit small (not shown) so i'm going to print a larger one tonight
there is a little bit of overlap on the top corners of the display, but nothing to worry about really
I've got a lilliput coming, but i'm not sure if i really want it now, as this is pretty good, and really cheap
Makerbot2 might just have to be my next acquisition. Thingiverse is AMAZING!!!Ravecreative said:Mate, if that's an offer, i'm on the next flight - LOL
i've got a makerbot replicator 2, and to be honest its one of the best things i ever bought.
no building or setting up, just use it straight outta the box
i love it
That mount on the back of the transmitter, i drew in about 5 mins, then printed in 30 mins - simple
The best thing though is http://www.thingiverse.com, there's loads of stuff you can print that already been designed. Like prop guards for the P2, fpv holders, theres even loads of quad/tri/octo copters on there, just download them and print your own. People have printed quads and they have video of them flying them. It's sssso addictive.... roll on the next hobby
So, the GoPro was generating the OSD and you were able to kill it then?Ravecreative said:sorted it
it was the osd from the gopro - how funny!!!
Yeah pricey, but that monitor looks awesome....and I can also use it with my D800 and Sony camcorder as a confidence monitor or director's feed. Do you know if the antenna is removable?Ravecreative said:Lilliput 664w with a canon battery on the back.
But it's 3x the cost.
I think for the time being, until the Lilliput turns up, I'm gonna activate the IOC HL and
Hit this and fly it back to me if I lose connection.
Just need to practice a blue screen strategy, just so panic doesn't set in.
Wish there was a way to switch off the charging function to the GoPro. What do you anticipate the hit will be to flight time, 7-10 mins?Ravecreative said:FYI
Just did a soak test on all the fpv gear running from full charge
Avl58 tx, mini iosd, gopro 3+ hero black (which charges all the time it's running btw)
and p2 switched on but not flying
The monitor with built in 3.7v 2000mah battery and 5.8ghz receiver (built in)
The monitor lasted just under 2 hours on a full charge
And after 2hrs the p2 was down to 25%
Just shows how much the tx, iosd and gopro pull
No wonder it effects the flight time so much
I might put a switch on the p2 fpv gear, so I can switch it off when I don't want to use it.
Yup, I was thinking the same thing. It would be a small weight penalty, but would likely give you back several minutes in the air.Ravecreative said:Yeh it's gotta be around that amount.
Might be worth using a lightweight lipo to run the fpv.
Also I spoke to lilliput uk and they say the aerial is removable
