Vertical lines on iPad monitor and recorded footage
I recently replaced the yaw gimbal arm on my P3 Pro, which was sucessful. However after the repair, which included removing and putting back on the ribbon cable, I now see lines on both the iPad monitor and the recorded video. Does anyone know what's causing this? Thanks
[file]lines|none[/file]
Double check all of the cable connections if that does not correct it replace all of the ribbon cables. If you did not have this problem prior to the repair then it was introduced at the repair.
Did you found out what the problem was, what was causing your vertical lines problem?
intertronixlabel
