V3.0 or V3.2
And here's a related question (the OP may already know this - but I don't): if I have firmware 3.06 installed and I open Assistant 3.0 and attach the Phantom, will it back down to firmware 3.00?
V3.0 and v 3.2 refer to the assistant software not the firmware version. If you run 3.0 and update the firmware you will get 3.04. Running 3.2 and updating will give you 3.06.
In this case it will back down to 3.04 because that is the last version available with assistant 3.0. If you had 3.0 and moved off it you can not go back to it. So assistant 1.08 gets you firmware 1.08. 3.0 gets you 3.04. And 3.2 gets you 3.06. I am not sure about assistant 2.0 for some reason!
Thanks Tracer! I appreciate your input.
biggest difference I know of is that 3.0 doesn't have the 2 meter per foot restriction... 3.06 does.
jorge sanchez
