Using meters & feet together
Hi, would anybody know if you can use feet & meters together in the Go App, as we use meters on the ground & feet in the air? Would be handy to know for a flight test. Cheers.
You cannot use them together, but you could switch the units in the DJI GO settings mid-flight.
DJI Go App is not that flexible.
are you sure they cant be used together? in the settings, i have imperial. BUT in the return to home menu, i see the highest elevation to go to is in metric! very confusing.....
I've found some annoyance (bug?) in DJI Go where if I change some camera setting, it shows the older one on the main screen unless I hit the one I wanted again. Sometimes it is stuborn to change and shows the previous one on the main screen so I have to hit Truecolor and then D-log to get the main screen to show the D-log change. Perhaps the Imperial/Metric is doing the same? It's an odd behaving app at times.
There is no way to change this. It has always been this way. Hopefully DJI will fix it someday.
Reactions: captainmilehigh
