upgrade board data spec
hi guys,
i was trying to hack my upgrade board in order to get a can bus port as suggested here : :twisted:
http://www.sarawuth.com/2014/01/dji-pha ... -bus-port/
I have done a really bad job. :oops:
and when plugged the battery for exactly 1 sec to test the board.
smoke came out of my welding wire. :(
I imminently unplug the battery, welding wire got disconnected because of the welding.
I cleaned the area hook up the battery
and no smoke no warm up no smell no nothing but green led is blinking and the board is working
so it seems. ;)
it seems like the smoke came out of the welding and after disconnected its off.
I then made the job better test again and everything looks OK :|
I get a normal reading from meter, but i don't know for sure were ever the board is really OK.
I am trying to find out if I can make any test before hooking up naza :?
like checking the voltage that going throw the naza link cable ? :?
or any other cable ?
does any body know what is the suppose to be output voltage and spec of
all of the exit connection that comes out of the board? :?
can it burn my naza ?? :?
can I all so check the can bus port I have made?
again anybody knows what should come out from can bus port ( volts ) resistance ?
thanks allot
Jerry P
