Updating firmware
. Long story short. I repaired my drone and when I got it put back together it says I have software inconsistencies. And I need to update. What are the steps I should do so it updates correctly to the new firmware
Did you replace the camera? Just update it like you would normally do.
I normally don't update. Only am not because I have to and with all the new firmware problems I'm hesitant about doing it
Replacing the camera and board is why you are getting the notice. The camera needs a update. Use the same firmware the drone already has. There is code the camera needs.
Each major component has its own part in the firmware. All must match to be able to perform correctly or perform at all.
tutilld
