Hi what firmware is the best to use 1.07.9 1.08.10 dji or 1.09.2 I'm using laptop to put on memory card then to drone if this fails it's going to a phantom repairer thanks in advance also once I've done drone do I need to do controller
I'm not sure what one causing problem as 100ft upwards and out is the best I've had even though altitude is set at 400ft and unlimited for distance it's now going to be looked at by a dealer before I give up lol and keep loosing connection I have 2 controller 1 standard 1 argtek and both the same someone said could be firm wareAre you having a problem with the drone OR the R/C unit........is that why your wanting to know what update to use ?
