Update problem
After update when I power the P3P on I just get a loud beep. Doesn't connect to the controller. When I check the update this is what I get
==========2015.08.04 14:12:09==========
Packet: /mnt/usb/P3X_FW_V01.03.0020.bin,
Upgrading ...
Result: Success
Result: Success.
========== 2015.06.17 13:51:31 =====================
Packet: P3X_FW_V01.02.0006.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.06.20 07:15:05 =====================
Result: Abort.
========== 2015.06.20 14:42:07 =====================
Result: Abort.
========== 2015.06.21 12:32:42 =====================
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
Result: Abort.
========== 2015.06.21 15:30:38 =====================
Result: Abort.
========== 2015.06.21 15:35:27 =====================
Result: Abort.
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
========== 2015.08.04 14:10:27 =====================
========== 2015.08.04 14:14:40 =====================
========== 2015.08.04 14:32:31 =====================
========== 2015.08.04 14:37:52 =====================
It looks like everything should work, but all I get is the loud beep.
Yes I updated everything. Now under overall status I have a red triangle that gives me Gimbal cannot receive MC data
Solution Check the 8 pin plug that connects the damping plate and the aircraft. They are not loose.
After the update all seamed fine. I changed the battery and that is when the beeping started. Put the first battery back in and the same thing.
mithRSM
