D
Deleted member 18853
Guest
Re: UNOFFICIAL Vision App for Android (Distance, Speed, etc)
If the application pulled more data when it synced the maps it would be possible. The Google map API allows for retrieval of elevation information and from there one would only need to add calculations, relative to home coordinates (for example) and then add/subtract as appropriate for each way point. I cannot comment on how easy or difficult it would be to implement as I am unfamiliar with the source code but it would be possible.
efloyd said:Is there any way of making ground station way point elevations based on current location of each way point and not based on the elevation above the home point. 200 feet may be ok for above the home point, but a 200 foot setting over a way point that happens to be on a hill may cause the quad to fly into the trees or the hill. It would be great if it were possible for the quad to maintain the same height no matter what the topography was like.
