- Joined
- Jan 26, 2015
- Messages
- 228
- Reaction score
- 61
CloudsNeverDie said:You're welcome! These two bugs were very easy to fix, both of them one-liners, and it's kind of sad that DJI didn't bother to fix them. Still, easy enough for us to do it ourselves.
Note one of the trade-offs with the video size here is that the video is now stretched out horizontally a bit, so it might no longer have square pixels and a perfect 4:3 aspect ratio like the raw 640x480 video stream. I think it's worth it to maximize use of the display, but if it turns out to be a problem I can always adjust it down a little and add some black bars on the left and right.
CloudsNeverDie said:Jetfixer said:Good work, Thanks! Also, for anyone who has been thinking of using the Moverio's, Epson just dropped the price by $200.
Ooh, where do you see this reduced price?
CloudsNeverDie said:mohan said:Excellent work
Has the compass issue been fixed? When I tilt my head the aircraft orientation moves...
Not yet, but I was just looking at the code for this, and I think I can fix it easily. There are two causes. Firstly, the BT-200 has two compasses (glasses and handset) and the app is using whichever is the default (probably the glasses); I can change it to always use the handset. Second, the orientation reported by the glasses is relative to the screen, which is oriented perpendicular rather than parallel to the ground, screwing up the orientation. I'll change it so that it uses the handset, and I'll assume the handset is oriented sideways with the cable coming out on the left.
mohan said:I also noticed that the live camera page closes from time to time and returns to the main page. Need to click camera icon several times while flying. Not sure if this is down to my setup with the dronexpert mod using a GoPro 4 Silver on a zenmusse H3-3D on a Vision 2 +. I have the sleeve for the original Vision 2+ camera and will try with that
I don't see that issue, so it could well be due to the dronexpert mod; please do try the original camera.
CloudsNeverDie said:You probably need to install Google Maps. To do that, you'll need to root your device first - you can find instructions on how to do that by Googling for it. I used Baidu root.
CloudsNeverDie said:I guess Epson didn't want to go through the lengthy Android certification / Google Mobile Services approval process. Maybe they also didn't want the Google Play store on the device because it would compete with the Moverio App Store.
Still, rooting only takes 10 minutes...
CloudsNeverDie said:Here is an unofficial version of the DJI Vision app, based on ilovecoffee's mod of the same app, which includes the following bug fixes and improvements specifically for BT-200 users:
- Fixed the "video offset" bug (see https://www.laurensvanduijn.nl/wordpres ... -47-06.png). The video now fills the entire width of the screen still leaving space for the toolbar on the right edge.
- Enlarges the video view to be full screen by hiding the toolbar at the bottom of the screen.
- Forces the app to use the compass in the controller rather than the one in the glasses, so the radar and ground station views work correctly. Mount the controller with the Epson logo on your left and the buttons and the cable on your right.
- Fixed a small bug in the Ground Station code that prevented it from opening. You can now swipe left in the camera view to see the Ground Station (after you have first enabled it in the Settings page of course). For this to work right you'll need to root your device and install Google Maps.
Current version: v1.2 (20150314), based on v11 of ilovecoffee's mod, which in turn is based on DJI Vision App 1.0.54.
The APK can be downloaded using this link. Side-load in the usual way. Make sure you have turned on "Auto-rotate trackpad" in Settings (under "Language & Input"). Enjoy!
http://www.droidbin.com/p19gd474nnd4f1khs4lbah1evg3
If you want to say "thank you", please use this link when you purchase anything from the DJI Store, and I'll receive a small reward from DJI: http://click.dji.com/AbAiNwu-GP6O5Qmy
Yours,
CloudsNeverDie
CloudsNeverDie said:jaykay2PT said:Thank you for this, the wait for DJI has been inexcusable, especially, as you say, a two line fix!
One question, on the GS part I am getting a very basic map with all labelling in Chinese and NO satellite view, help??? please
