THE ULTIMATE P4 PROP BALANCER !!
Rio Rancho NM
Hey guys,
This prop balancer is the same principal as the
Ultimate P3 prop balancer I built a few months ago (see link below)
One very small point of contact resulting in the least friction possible.
I used the Top Flight prop balancer, the balance shaft is .125 (1/8")
I turned the shaft down to .116 and the fit was perfect, I'd turn down to .118
first and go from there to account for any difference in vernier calipers,
you want the fit to be a light press in fit by hand, no slop or that will
affect the "center" and wont balance correctly.
Note the air gap, it about .060
The Ultimate P3 Prop Balancer
I balanced 12 P4 props, 3 were perfect, the rest were blade down out of balance. (thats a lot)
I'm a firm believer in balancing props, I can go on and on regarding the benefits of balancing a rotating mass.
I spun the shaft in a drill and used a fine file to groom it to .116
I groomed a total length of 1/2",
I used vernier calipers to check the diameter at the tip and at
the opposite end, I got .116 at both. I was pleased with that.
I got one of these balancers and modified it as GreggC suggested. It worked perfectly. One big disappointment for me...all 8 props I checked were in balance. Checked them twice. I was really looking forward to balancing some props....
Hey guys,
Awesome! I want one. Are we selling these or are we being dirty socialists and I can get this on thingverse
I love it. ^^^Sarcasm above. I always feel like I'm not giving enough love to my props. For example, yesterday for the first time ever I chopped up some leaves with my props and didn't know if I should keep using them or not. Everything seemed fine.
jumperswaves
