- Joined
- Aug 16, 2015
- Messages
- 21
- Reaction score
- 2
- Age
- 51
Most prevalent cause is heat-- what temps are you flying in and is it in direct sunlight?P3 camera range issues with iPad.
Yes, I have one of the wind surfers, but I just received the DBS Intellilite that I have to install-- and that should kick up the signal significantly. Several posts on the forum regarding those. But the key with the IPAD is to keep the heat down.Is there a range booster?
Get back if that doesn't help you -- be sure to close down all other apps running in the back ground and fly in airplane mode after you have your maps cached on your device. The will eliminate some of the extra processing going on that also creates heat that just adds to the issue.Many thanks.
