- Joined
- Oct 24, 2017
- Messages
- 25
- Reaction score
- 21
- Age
- 35
Attempt to create cinematic footage-
Phantom 3 Standard
2.7K/24fps
D-Log/(+1,+1,+1)
Manual Mode /ISO 200/ Shutter Speed 400
Hope you enjoy
Thank you so much for the in depth information so basically my ND8 filter is useless.. should i just use it as jello-effect preventing lens then?The aim is to get your shutter close to twice your frame rate, in this instance you would need an ND32 with your ISO@100 (there is no good reason to run a higher ISO with an ND of any value). It might be that an ND16 would have been adequate for some if the takes though where you are seemingly under exposing by a stop- it might also be you went in a bit hard in setting your levels in post.
