so you are saying all I nerd to convert from a advantage to a pro is the gamble board from a pro? so the cameras are the same? So then when I update firmware I use the Pro selecton?You only need the gimbal mainboard to convert. You can buy a crashed gimbal off eBay and use the mainboard from it. 5 screws and plug in the ribbon cable...
Where would I get a new main board in original case with fan? I tried at DJI but they couldn't help me. I thought they would have a replacement part. Thanksyes cameras are the same.
so if you are going to "upgrade" to 4k just get the mainboard already in its original case with the fan and you've got yourself a P3P now.![]()
I'm have a p3p that needs gimbal repair. I need yaw arm, roll arm and ribbon. Any best suggestions where to order. I'm in ontario canada
do you have the camera board and fan to convert my advantage to a pro?i have all those in stock and located in Minnesota
