I have ordered the sundance edition kit from DSLRpros.com and am waiting delivery. Here are the specs
DJI Phantom 2 Go Pro Aerial Rig
DJI Zenmuse H3-3D Gimbal (3-Axis gimbal pre-installed and tuned)
DJI Self-Tightening 9" Props (set of 4)
DSLRPros 9" Carbon Fiber CF Props (set of 4)
DSLRPros 9" Prop Guards
DJI On-Screen-Display (OSD) - provides basic flight data over FPV Live Stream
DSLRPros Futaba D8FG Radio Transmitter (for Long Range, Reliability & Special Advanced Control Profiles)
Deluxe DSLRPros Radio Tx Lanyard
DSLRPros Long Life 2600 mAH LiPo Tx Battery
3 Total DJI OEM 5200 mAH LiPo Batteries
2 Total DJI Flight Pack Charging Blocks (Required to reduce charging times via parallel charging)
Special Edition Tough Case with DSLRPros pre-cut foam
Integrated 5.8 GHz Long Range Diversity FPV System (7" HD Field Monitor, Long Range Diversity Rx/Tx, CL/Panel Antenna)
Most important is the FPV that is pre-installed. My question is can I install a fatshark FPV system and utilize both systems at the same time? I could have a 2nd person watching while I am controlling video and pilot at same time. What would it take to make this happen with my current build? Or is it one fpv and that's all you get? I promise I will stop asking so many noob questions soon enough..
