Strange white line on map
Hi all,
I've noticed a straight white line on my GPS map that goes from a point I recently took off from (multiple flights ago) to my most regularly used location in my back yard. Looks as though the home point gets set correctly with the "H" tack and I can see the green line follow the bird correctly during flight. What is this white line? Just did a firmware update and imu calibration and it's still there.
Also, app always says 100% battery when looking at the cells in the app, yet clearly shows less than 100% battery on each cell (example 4.07 volts) and also shows the correct percentage on the home screen (in this case 80ish %). Again, newest firmware and fresh calibrations.
Thanks!
Are you talking about your actual flight route that gets drawn on the map each time you fly?
