Stop in a each way point....?
I set a litchi waypt mission but can someone tell me why it stop for like 1 second at each wp? I do not have it set for that as an action
Are you using curved lines or straight lines in your mission to each waypoint? I use curved lines to keep the drone moving as I don't stop and takes photos etc.
Its set on straight lines but the mission is a straight mission with hardly any curves to take.
In that case, it will pause for a bit before it takes off to the next waypoint. Try running the mission in curves, reduce the size of the curve to about 5mtrs and see how that goes. It may pause slightly as it gets to each WP but will be better than stopping. You can increase/decrease the size of the curve accordingly.
Okay gotcha i will try that & see how it goes. Thanks
No worries, probably need to consider that technically the drone doesn't actually get to the waypoint and any actions such as take photo at the point probably won't work. I only film during the trip and if I need photos, I edit them post filming.
Update... i tried the above advise (put in curves) & it flew the mission non-stop just like i wanted
Don carlos
