Stock P2V+ Range - It is NOT 800 meters!
DJI says that FCC Communication Distance is 800 meters (http://www.dji.com/products/compare-phantom)
In the video below I only used the FPV booster app on my iPhone. I was sitting in my car, and held the controller as stable as possible, pointed at the Phantom. of course at some point I could not see it, but I did the best I could.
VERY happy with the results! All stock!
[youtube]https://www.youtube.com/watch?v=8BqyWB3-pSM[/youtube]
Nice.
On a side note...
What country you in?
I noticed your satelite count maybe problematic in confined or geographically raised areas. Worst that can happen is it may drop into ATTI and you'll end up with a drift-away or auto-land-away.
In an open field like that, you should be getting 9+.
Does satelites drop when you hit the record button?
If so, may need to put a tin foil hat on your phantom.
i do have a problem with satellites! i could not even get 6 satellites, so I did the below, and now I get 8 satellites. I live in Cyprus. Got any suggestions on this satellites issue?
loracle
