- Joined
- Jan 2, 2014
- Messages
- 154
- Reaction score
- 0
Re: Phantom 2 Vision 1.7 KM (5,600 Feet) Long Range Test
Interesting results.. Thanks iDrone for this testing
iDrone said:Well I just found out my imported test pigtail was the culprit. I replaced it with a higher quality cable and the results are much better & consistent.FPV col said:Yes that's definitely a few "if's"but well explaind thanks.. Just for the record I'm using the same output side you quoted and can get good range with my patch mod..
Test conditions: Fully charged Vision & Extender batteries tested off the top 10-minutes, ImmersionRC w/30dBi attenuator in Peak mode, direct connection via RP-SMA heavy gauge pigtail to Extender, Vision / Extender / Controller / iPad mini all linked.
Results: "i" terminal*: 112.20mw peak, 107.98 nominal / "D" terminal*: 184.78 peak, 177.83 nominal
Interesting thing about the "D" terminal is that it drops to 158.49mw when playing back videoclips over the iPad mini. The "i" terminal doesn't budge when doing the same thing.
Sorry about the earlier numbers, still be interesting to see what other P2V'ers extenders are putting out.
iDrone
* {"i" terminal is closest to the silk screened letter "i" in DJI, and "D" terminal is closest to the letter "D" to avoid left-right ambiguity}
