Status Light shorting out
My status light is shorting out. I opened the body and I'm able to get the light to work by moving the wires on the panel that connects the light. Where can I get a replacement?
Thank you.
May be a simple loosen soldering point/wire. You can unscrew main board, then 2 small screws ann check led panel/wires instead replace all the unit. (I've not seen this part as spare with any dealer).
Any idea where I can get a good solider gun. It's been a bazillion years since I've soldiered anything! Also, what type of soldier should I use?
intertronixlabel
