Look promising, but these can only be used for niche shots (sky+landscape) at a certain gimbal angle. I can't imagine buying these unless I'm making a lot of money for the pictures [emoji3]
I thought about it....Pics or it didn't happen! Just put a raincoat on your Phantom, it'll be fine.
I asked some SRP-related filter questions here but I also have to ask another question...
is it just me or do you also feel like you are breaking the crap out of the camera gimbal when trying to slide these filters on and off?
Nice, I tried that and I think it helps.LOL... Yep... really tight and almost a "pressurized" feeling right? I've already made this comment to SRP a few days ago. They are now notching the o-ring to allow air to escape relieving the vacuum pressure when installing and uninstalling on the camera lens.
AT YOUR OWN RISK BUT I QUICK AND EASY SOLUTION: I personally did this to all my existing filters o-rings with an exacto knife. Remove the rubber o-ring. Just pinch the o-ring together to create a tight curve on an outside edge. Then on that little curve or bend, shave off a tiny bit (1-2 mm) of the rubber o-ring creating a "leak" where air can escape. Took me about a minute for each of my filters. Now mine slide on and off with minimal effort while staying snug and safe for flight.
For giggles I also tried it without the o-ring altogether but then it slides on/off too easily. It definitely seems like a slightly more forgiving o-ring would make a world of difference.
It might also feel "cheaper" but I wonder if it would also weigh a lot less if the lens frame weren't aluminum (or whatever) but plastic.
Your videos are always great. I assume the "before" color grading portions are simulated?Here's my first test with this filter
Thanks and the "before" is straight from the camer with no adjustments.Your videos are always great. I assume the "before" color grading portions are simulated?
Ohhhh, so all that was done in post then. Wow, that must take a lot of time and patience.Thanks and the "before" is straight from the camer with no adjustments.
I have Final Cut Pro -- I need to learn how to do that.
Sorry for all the questions for you but I do have another... do you have any advice for dialing in settings when you take pics/video? Especially with the SRP filters on? I find that it's so hard to see what's on my iPad, even with a sun shade that I feel I'm mostly guessing. Are there some settings you leave along and others you change?
Hi fhagan. Do u rem the iso. Fram rates and shuttr speed for this footage?? Its very nice indeed. Fyi. Ive been using davinci resolve lately. Any experience w it? Sorry if u already answ this. B
